Page 6 of 6 FirstFirst ... 456
Results 51 to 57 of 57
Thread: high compression 2.7RS engines?
  1. #51
    The Netherlands
    You can drive my RS to see what you miss on the 2.4S...for a small fee like selling the 2.7 P and C's he he.
    Remember I still need to visit you with the car..
    Cees
  2. #52
    Senior Member swisscheese's Avatar
    Jan 2003
    The Netherlands
    hey Cees!!! ja, man! happy to "see" you here! As you can tell, I'm about to (re-)start the project, after an absence of 15 years.. Need to catch-up soon!
    911S 1973
    Early 911S Registry #176
  3. #53
    The Netherlands
    Sure Tom, I'll be home in a couple of weeks, need to do something to boost your project! I'l put some Firezone 102 fuel in the tank for Xtra power..
    Cees
  4. #54
    Jan 2003
    The Netherlands
    ok, so the options there seem to be:
    1) remain bone-stock 2.4S
    2) 2.4S base w. 2.2S pistons High Compression
    3) 2.4S base w. 2.7RS p/c
    4) 2.4S base w. 2.7RS HC p/c
    Assuming that for all 4 options, the base motor needs to be treated, what are the added modifications per item required? Cams remain same? Fuel pump adjust? etc.
    911S 1973
  5. #55
    Jan 2003
    The Netherlands
    Ok, so I've found another set of 7R cases, which opens up all alternatives (and putting away the matching number cases). What's needed for the high compression 2.7RS and what output to expect? MFI pump can handle this? Thnx.
    911S 1973
  6. #56
    Our 2.7's at 8.4 and 9.2 comp, don't have very much power difference, generally around 225 to 235 hp and not necessarily because of compression. Sometimes a motor just has right stuff and makes power. Rumor has it that Factory motors that made more power were pulled off the line and installed in VIP customer cars. Don't worry about the injection pump, my 3.4 race motor uses a 2.0L pump. They can produce all the fuel delievery u need.
  7. #57
    Jan 2003
    The Netherlands
    thanks. The funny part is, that experiences from others with upping the compression on a 2.4S by using the 2.2S pistons, (supposedly) makes a huge difference; But upping compression on the 2.7RS doesn't..?
    911S 1973
  1. FS: High compression pistons...cheap
    By speedo in forum For Sale: 911 Parts
    Last Post: 01-15-2014, 12:30 AM
  2. 2.7 high compression p's and c's
    By tfiv in forum Technical Info
    Last Post: 10-04-2005, 07:20 AM
  3. Camshafts for a High Compression 2.4S
    By Edwin Ek in forum Technical Info
    Last Post: 01-10-2005, 04:37 PM
  4. High Compression 2.4 S Motors
    Last Post: 01-27-2004, 09:51 AM
  5. High compression test readings
    By Baddger74 in forum Technical Info
    Last Post: 02-21-2002, 03:30 PM
