Results 1 to 10 of 18
Thread: How do you remove the gauges on a '69 911?
    So the gauges on the '69 911 have the two retention bolts on the backside to hold them in, unlike later gauges that can simply be popped out.
    So here's my stupid question: how do you get to the backside of these gauges to unscrew the *$&@%%*# retention bolts?
    I want to repaint my gauge trim rings. I tried to approach from underneath the dash this morning and couldn't even see the backside of the gauges. What am I missing here?
    Thanks to all!
    2015 McLaren 650S spider
    2001 Ferrari 550
    2010 Ariel Atom 3
    1979 Ferrari 308gtb
    Paid-up Registry Member & proud of it!!
    Nov 2002
    San Dimas, CA
    Re: How do you remove the gauges on a '69 911?
    Thanks to all!
    I have a '65, and it definitely has two "bolts" on the back of each instrument. I had thought the long wheelbase cars just used the rubber ring, but you have the genuine article and I don't.
    They aren't actually bolts. Each gauge has two threaded studs, and thumbscrews go on those studs and hold 2 L-shaped brackets which secure each gauge (the speedometer actually has a single C-shaped bracket).
    You get at them from the trunk.
    1. Remove your trunk carpet
    2. Lie down in the trunk
    3. Shine a flashlight up there and hope you can see the gauges
    4. Reach up and unscrew the thumbscrews
    5. Push out the gauges
    6. Disconnect wires, speedometer cables, etc. and finish removing the gauges
    7. Order new thumbscrews because they will have slipped from your fingers and rolled away somewhere.
    Seattle WA
    And draw a diagram of each gauge, and label each wire!!!!!!!
    Don't ask me how I know this.......
    Eric
    Nov 2002
    San Dimas, CA
    Eric
    I was going to point out that little step, but I had trouble organizing the rats nest of wires when I pulled my gauges.
    About all I have retained from a Master's in Electrical Engineering is the ability to trace wiring diagrams. I managed to reverse engineer it. If you aren't really comfortable with wiring, you better make some advance preparations.
    My 69-911 has a cardboard (black) cover over the gauges. Depending on which gague you eant to remove you will also have to remove the defroster tubes and the distribution box...
    I haven't done this for 5 years so I may have forgotten something.
    Be very careful the rubber rings on the gague where it enters the
    the dash board.
    Not a stupid question. Mark all the wires.
    Ed
    Ed Barnett
    RGruppe #124
    Northern California Racing Club
    American Racing Club
    Member, Northwest Hillclimb Association
    I have some extra thumb screws for anyone who loses one or has already lost one. I also have an extra bracket or two.
    As for removig the gauges, I thought the 69 model year popped out from the front as well. The early SWB gauges are a pain in the ass to work on...
    912->911 conversion
    Nov 2004
    Calgary, Alberta, Canada
    I was just digging this up and had to vent as I try to reinstall the gauges in my 69 - man-o-man did Porsche employ a secret army of double-jointed, left-handed, long-fingered elves to get these gauges in? I don't recall being so frustrated and cramped doing anything in my whole life.
    Keith Adams
    Early 911S Registry #906 | PCA member IG: @912R
    1969 Blutorange 912R - 912 to 911 conversion
    1969 Mercedes 280 SE (W111) Coupe
    Luft gekuhlt Bummler's Avatar
    May 2005
    The Valley...
    Having long skinny arms with small hands helps a great deal...
    Stefan Josef Koch
    RGruppe #194/SRegistry #1063
    2015 Porsche Cayman S
    Oct 2008
    Burford, ON, Canada
    They used a well trained octopus at the factory.
    Addicted since 1975, ESR mbr# 2200 to 2023 03
    Senior Member Carparc's Avatar
    Costa Mesa / Long Beach CA USA
    Take the big tach out first from the trunk, then you can stick your hand in the hole from the interior to get to the other ones, fairly simple..... ;-)
    Good luck.
    Henk.
    Henk Baars owner of CarparcUSA LLC
    www.CarparcUSA.com
    www.911WoodDashRegistry.org
    S Registry #1490
    '68 911L Targa Sea Green
    '66 Volvo 123GT
    '62 Volvo P1800
  1. How to remove dash pad on 73
    By Mark Wilson in forum Technical Info
    Last Post: 08-17-2013, 05:27 PM
  2. 71 911e a/c keep or remove
    By mishwa in forum General Info
    Last Post: 07-27-2013, 04:08 AM
  3. How do I remove lens from H1?
    By Alan B in forum Technical Info
    Last Post: 10-03-2007, 09:57 AM
  4. How to remove A/C system?
    By berettafan in forum Technical Info
    Last Post: 11-09-2006, 11:09 AM
  5. How do you remove an SWB dash?
    By 304065 in forum Technical Info
    Last Post: 10-03-2006, 11:34 AM
