Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: How do you remove the gauges on a '69 911?
  1. #11
    Quote Originally Posted by lkadams View Post
    man-o-man did Porsche employ a secret army of double-jointed, left-handed, long-fingered elves to get these gauges in?
    I think they had that job farmed out to China
  2. #12
    912->911 conversion
    Nov 2004
    Calgary, Alberta, Canada
    Thanks for the moral support! Henk your tip may prove to be fruitful - I think I foolishly put the tach in first because it was easiest.
    Keith Adams
    Early 911S Registry #906 | PCA member IG: @912R
    1969 Blutorange 912R - 912 to 911 conversion
    1969 Mercedes 280 SE (W111) Coupe
  3. #13
    Junior Member
    Nov 2021
    chicago area
    Is there any trick to just removing the tach (other than as stated earlier on this thread)? Mine sticks till you tap it...
  4. #14
    You'll also have to remove the steering wheel and column mast jacket.
  5. #15
    Sep 2012
    Colorado
    BTW, this job isn't nearly such a PIA if it is done before the air ducts, blower, steering wheel, etc. are installed, as was probably the case on the assembly line at Zuffenhausen.
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
  6. #16
    Aug 2020
    SF Bay Area
    The tip about using the tach hole to remove the other gauges is only true if you have very small hands and absurdly short forearms, and you will never get the clock or fuel gauge out from the tach hole. And forget about using the speedo or oil gauges holes -- way too small to get a hand through, and you will never reach the far knurled nuts on the fuel / clock gauges from there.
    Just remove the blower assembly and steering wheel and do it from the trunk. Removal can be done just by removing the blower motor and upper blower hoses if you know what you are searching (blindly) for. Installation is more difficult.
    - 1969 911T Ossi Blue #3981
  7. #17
    Longhoods forever! silverc4s's Avatar
    Apr 2003
    Somewhere in Texas
    1970 was the first model year for the gaskets. 1969 had a lot in common with SWB models, then somebody got smart and revised a lot of early design shortcomings for 1970 onward.
    Bill Conway, Early S Registry member #254
    1970 S, 2.2L Silvermetallic Coupe
    1973 T, 3.2L Black Carrera Targa
    1969 T, 2.4L Silvermetallic Targa
  8. #18
    If you get one thumb screw removed, you can sometime rotate the gauge for easier access....
    John Schiavone
    Connecticut
  1. How to remove dash pad on 73
    By Mark Wilson in forum Technical Info
    Last Post: 08-17-2013, 04:27 PM
  2. 71 911e a/c keep or remove
    By mishwa in forum General Info
    Last Post: 07-27-2013, 03:08 AM
  3. How do I remove lens from H1?
    By Alan B in forum Technical Info
    Last Post: 10-03-2007, 08:57 AM
  4. How to remove A/C system?
    By berettafan in forum Technical Info
    Last Post: 11-09-2006, 10:09 AM
  5. How do you remove an SWB dash?
    By 304065 in forum Technical Info
    Last Post: 10-03-2006, 10:34 AM
