Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Spacers for "R" Wheels on '73 S
  1. #11
    Goldmember ttweed's Avatar
    La Jolla, CA
    Originally posted by a911s
    The only tire that worked on those wheels on my '72S was the old R-1 with the flat sidewalls. No other 225 tire (Bridgestone, Kuhmo, or Yokohama) would work
    Actually, Randy, the only two tires that size I ever ran on my car were the old BFG R-1 and the Yoko A-008RSII. This was before I flared it. I had no problems with either one, but did have uprated T-bars, ARBs, 1.5 degrees negative camber and had to roll the fender lips. I have seen other people fit them OK on the left side but not the right. Maybe my car is golden. With the RS flares, I can run a 23x10.5-16 Goodyear slick on an 11" rim by just pulling the lip out 1/4".
    A local autocrosser here had his stock '73E set up with the Hoosier 225/45-15 R3S03s on 7s and they worked fine for him also.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
  2. #12
    7R's
    Edwin,
    FWIW, I've been running 7R's front and rear with 5/16" spacers. Before with 205 x 50 008's, now with 205 x 60 AVS Intermediates.
    HTH.
  3. #13
    6.5 mm factory spacer with use of 215-60-15 tires in the rear, same in the front unless you remove the strut dust cover.
    Jeff
  1. WTB: Superlight "Classic 8" 7x15" wheels w/ ET29
    By LeftFootBraker in forum For Sale: 911 Parts
    Last Post: 01-20-2014, 10:35 AM
  2. FS "RS" "RSR" 380mm Thick Grip Steering Wheels
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 08-10-2009, 07:46 AM
  3. WTB: Blaupunkt Radio "Behind the Dash" Spacers
    By t6dpilot in forum For Sale: 911 Parts
    Last Post: 03-05-2008, 01:42 PM
