Thread: suspension bushings
    suspension bushings
    1. What are signs of worn suspesion bushings?
    2. Has any one change all their bushings including the sway bar bushings?
    3. And if so did it make a differences?
    1. If the rubber is hard, cracked, and/or distorted.
    When it gets hard, it gives a rougher ride. I have new bushings ready to install, but I haven't had the intestinal fortitude to tackle the job yet. It looks kind of hard and tedious.
    I did replace the rear sway bar bushings, and it was a bear. You have to jam a large piece of rubber into a much smaller piece of metal. I did it with pliers, screwdrivers, and sweat. The rubber is pretty tough, so it can take a lot of abuse. I didn't notice a difference, but I might if I install the rest of the bushings.
    I live nearby, so give me a call. I need an excuse to install the rest of my bushings.
    Charlie
    '66 912
    '50 VW Bug
    '89 VW syncro Tristar Doka
    '83 VW Westfalia
    I just replaced all my front and rear anti-sway bar bushings.
    The car now drives very differently and tracks very true; no more wandering.
    It drives like a new car.
    I replaced my front A-arm bushings with urethane, and rear swing plate bushing with Neatrix. Huge difference- ride quality went down a bit, but the car is far tighter. Big improvement.
    David Schultz
    1973 911T 2.7
    R Gruppe #228
    Www.davidschultz-id.com
    www.pelicanparts.com/gallery/turbo_dave
  1. Recommendations: Suspension Bushings
    By 50/50 in forum Technical Info
    Last Post: 11-02-2011, 04:12 PM
  2. ya think i need some new bushings?
    By ttweed in forum Technical Info
    Last Post: 05-07-2006, 09:23 AM
  3. Need advice re: SWB Suspension Bushings
    By Porsche Rescue in forum Technical Info
    Last Post: 09-30-2004, 08:50 PM
  4. A-arm bushings- how bad do they get
    By neilk in forum Technical Info
    Last Post: 05-27-2004, 06:07 AM
  5. A-arm bushings
    By thback in forum Technical Info
    Last Post: 07-17-2002, 03:29 PM
