Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Regular.... S... L...T...E...?
  1. #11
    Nov 2002
    San Dimas, CA
    Re: Oh sure...
    Originally posted by Shawn
    Back when there were no E's or T's and the S was first introduced. There was...the other 911.
    Factory detuned so as not to steal any "thunder" from the S, the poor little 911 "normal" had simple narrow trim and spartan interior upgrades. 911 "normal" was lucky to recieve only a few mechanical upgrades after 911S wore them out.
    Poor little 911 disappeared after 1967 and was forgotten about. There are clubs, registrys, and forums for every model 911 out there...not for little 911 "normal"
    Please let me stay. Shawn.
    To be totally accurate, the 911 (sans sufix) wasn't detuned until the S arrived in 1967, and a milder cam with the new "S" headers left power about the same as the previous cars with the "Solex" cams.
    In 1965 at least, the 911 had an exceptionally opulent interior. It's trunk was trimed in the same carpet used in the people compartment of the 356.
  2. #12
    RS... No Improvement Needed?
    Oops... I thought that a RSR 2.8 would work. Too bad pump gas (91 oct) in Calif won't... sigh. Or the ign/distrib parts supply....
  3. #13
    Isn't there some some diff. in brakes and suspesion too?
    68' 911
    81' 280zx turbo (for sale)$4500 obo
    96' Honda Prelude
    03' Nissan Altima
  4. #14
    Oh sure...
    Bruce Anderson's "porsche 911 Performance Handbook" pg 56 states that "...the header system developed for the 911S was then used on the 911 Normal engine. The change in the exhaust system increased the horsepower, however, from 130 DIN hp to 140 DIN hp. Porsche felt the the difference betwen the S and the Normal would not be enough and took steps to reduce the engine's power to the original 130 DIN hp. To resolve the problem initially, a restrictor ring was intalled at the end of the header system where it joins to the muffler. For the 1967 models, in November 1966 new milder cam shafts were introduced to provide a broader, more-elastic power curve and to restrict the power to its former value for advertising purposes, and the restrictor ring was removed from the exhust system. The type number for this new engine was 901/06."
    I have a 901/05 engine and I would be pleased to show you the mentioned exhaust restriction. There are two ugly weld beads placed internally, about a 1/2 " inside both of the exhaust system
    manifold outlet bases.
    So there, Shawn.
    edit: spelling...again.
    67 coupe roller
    99 M96 2.5 litre
    early911s reg 447
    R Gruppe 399
  5. #15
    here is that...
    once factory detuned little 2.0 liter 901/05 engine.
    Shawn.
    67 coupe roller
    99 M96 2.5 litre
    early911s reg 447
    R Gruppe 399
  6. #16
    Shawn,
    Who ever said you were normal? You can stay.
    Chris Purpura @civilizedmisfit
    ___________
    Member #479
    Current Cars:
    1972 911T aka The "Civilized Misfit" Build
    See: https://www.excellence-mag.com/issue...vilized-misfit
    Miss February - EarlySRegistry 2023 Calendar
    1968 911S Ossi Blau/Beige Corduroy
    Past Cars:
    2019 911 Carrera GTS (sold, no regrets)
    73S - #1100 (restored and now somewhere in Europe)
    1997 993 Carrera 4S Black on Black (sold)
  1. Swepco or regular gear box oil?
    By rcnagel in forum Technical Info
    Last Post: 05-05-2011, 06:52 PM
  2. FS: A set for regular 69T Recaros
    By EA911 in forum For Sale: 911 Parts
    Last Post: 04-02-2009, 11:33 AM
  3. FOUR regular 6 x 15s
    By Rennman in forum For Sale: 911 Parts
    Last Post: 10-09-2007, 01:43 PM
  4. Help ! Need regular seat parts
    Last Post: 09-26-2005, 08:44 AM
  5. Karmann vs regular?
    By GRMPer in forum Technical Info
    Last Post: 03-10-2003, 04:59 AM
