Cain,
I'd love to see some pics of how the deep 6 front and 7R back wheels relate to each other - and the wheel openings on your car.
Please post pics if you get a chance.
Cain,
Jared
'73 911S #0793
'69 912_ #0602
Early S #0454
RGruppe #0391
Cain,
You better be bringing that badboy to Monterey in 3 weeks! I need you as one of my key drinking buddies.
I also have some R wheels in search of a car to wear them, so I will be picking your brains my friend!
2015 McLaren 650S spider
2001 Ferrari 550
2010 Ariel Atom 3
1979 Ferrari 308gtb
Paid-up Registry Member & proud of it!!
Greetings all,
I just fitted 7 Rs to my 68. Using 2 quarter inch spacers left the tire too close for comfort to the trailing arm bolts. A factory 22 mm spacer worked perfectly. Tires are 5.5 15 Hossier vintage race tires. There is 1.5+ neg. camber. Hope this helps.
Best,
Don
P.S. Thanks again to Nick Moss for helping me out with a wheel.
I'll be there WOLFMAN!
And I'll be drinking. But I gotta warn ya'...I'm actually taking my better half as my wingman. No worries though...she can drink with the best of 'em.
And yes...the 72 is Monte-Rey bound!
And on a note more directly related to the origins of this thread...thanks Don...I'll try the 22mm's.
Cain
______________
1972 911S Coupe
R212
And to think that I always thought your wingman was Chris Tallon!
Glad to see you now have a "wingskirt"
Wolf
2001 Ferrari 550
2010 Ariel Atom 3
1979 Ferrari 308gtb
The factory recommended 27mm spacers on the 7" wheels in '68. Does that leave too much room on the inside?
RGruppe #183
The 22mm spacers leave about a finger away from the tire hitting the bolts and look just right. Remember the R had flared fenders where the narrow 911 obviously does not. If it did I could go up a tire size. The 27 mm with the flares I am sure worked great with a larger tire. For my car the 22s are perfect.
Best,
Don
I'll try 22mm then, when I get to that point in my project. Thanks Don.
RGruppe #183
Jens,
I will have the car at Daytona. I will be happy to show you.
Best,
Don
Joel, the tires available at the time the R wheel was introduced (1967) were skinny and tall. Modern equivalents are not readily available. The tread width of a comparable modern day tire of equal section width is wider, hence rubbing is more of an issue, I found 16mm is the spacer width that worked best for me using R wheels with 215/60-15 or 225/50-15 tires in the rear of a '72 911.Originally posted by joelrkaplan
Randy.... thanks, I understand most of what you said but what do you mean by "too much for todays tires?"......I am thinking clearance is clearance....pls explain...TIA
Randy Wells
www.randywells.com/blog
www.hotrodfilms.com
Early S Registry #187
