Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: 911R wheels
  1. #21
    joelrkaplan
    Guest
    Randy, got it...thanks. On that car w/ those wheels and tires was your outside clearance very close to fender lips or more than enough?.........
  2. #22
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    Don's '68 rallye
    I'm not sure it could look any better! Congratulations on a great job. I can hardly wait to see it at Rennsport.
    Thanks for the photos.
    RGruppe #183
  3. #23
    More than enough clearance to the outside fender (1/2" w/ the 225s). I did grind down the closest spring plate bolt on both insides though, in order for everything to clear there. With a 215 you may not need to do this - each car is different.
    BTW, the set-up that Caine describes is the one that I have been using for the past eight years. A narrow-bodied 911 with 2.7RS spec MFI engine, 18mm factory sway bars, Bilsteins, deep sixes in front and 911R wheels in back (with a 16mm spacer) is essentially a '73 RS - footprint, chassis and power are all the same. Magical...
    Randy Wells
    www.randywells.com/blog
    www.hotrodfilms.com
    Early S Registry #187
  1. all we ever needed to know about 911R wheels
    By mjshira in forum Technical Info
    Last Post: 12-02-2011, 10:36 AM
  2. FS: Complete set of 911R Wheels
    By a911s in forum For Sale: 911 Parts
    Last Post: 06-01-2006, 11:02 AM
  3. FS: 911R wheels
    By K.B. in forum For Sale: 911 Parts
    Last Post: 08-09-2005, 05:45 PM
  4. 911R Wheels
    By JDStell in forum Technical Info
    Last Post: 07-26-2005, 06:25 AM
  5. I want to make 911R wheels!!!
    By SprintStar in forum Technical Info
    Last Post: 09-03-2003, 01:01 AM
