Thread: Oil Leaks
    Oil Leaks
    My newly purchased 73 911S has two oil leaks. When the engine is cleaned and left to sit overnight, there are two small leaks. One is directly below the center of the engine where it attaches to the trans. One is also at the center of the engine directly below the rear pulley. I suspect the front and rear seals since the car had not been driven much (5000 miles in the last ten years).
    My question is if the engine is removed, how hard is it to replace these seals? I've rebuilt engines before, but never worked on Porsches.
    Thanks for any suggestions.
    1973 911S
    1967 Alfa GTV
    2002 Miata
    It requires a special tool to reinstall the rear main and the main bearing seal that you are suggesting on the front (rear of the car) of the engine.
    Another leak source is the thermostat housing "O" Ring. Easy enough to replace on MFI or Carburetted cars. Not so easy on CSI cars. Check you pressure sender as well as they like to leak. The crankcase breather can leak as well. All of these can be handled in a matter of an hour or two.
    The rear main and main seal behind the pulley will take a day since you need to pull the engine and to do the rear main you have to remove the transmission and clutch assembly as well as the flywheel. It's not as awful as it sounds but it will try you if you are on your own. I suggest "pressing", pulling a Tom Sawyer or just plain begging for assistance from an able bodied person who can take instructions for the engine removal-reinstall.
    Good luck,
    Tom
    Early S Registry #235
    rgruppe #111
    admin_old
    Guest
    Before you pull the engine, make sure the leak source isn't from above. Gravity has a way of taking any leaks and depositing it on parts below it. Some likely culprits (from many possible) could be the oil temp. sender and, as Tom mentioned, the thermostat O-ring.
    Sherwood
  1. OIl pressure sender leaks, PN 901.741.551.01
    By caproader in forum Technical Info
    Last Post: 04-12-2009, 04:22 PM
  2. Oil Leaks?
    By A.T. in forum Technical Info
    Last Post: 12-14-2005, 08:52 PM
  3. Oil Leaks
    By Gavin English in forum General Info
    Last Post: 05-12-2005, 05:19 PM
  4. Oil leaks at pulley area
    By zaza in forum Technical Info
    Last Post: 12-17-2004, 04:48 PM
  5. engine leaks...
    By joelrkaplan in forum Technical Info
    Last Post: 10-30-2003, 10:12 AM
