Thread: Sunrrof \ Windows stop working when engine running
    My sunroof and electric windows stop working as soon as the engine is started.
    There is 12v at the window switch when the ignition is on, however there is only about 8v when the engine is running. At fuse number 3 there is approx 12v when the engine is off and about 14v with the engine running.
    When the engine is off the windows work perfectly so this does not appear to be switch related.
    Anyone have any ideas? What would cause the voltage to drop at the switch but only while the engine is running ?
    72 911s
    I have cleaned up the earth that is used for the windows.
    It makes no differnce.
    Thanks anyway.
    72 911s
    I would suspect an "earth" somewhere where one shouldn't be...but why only when the ignition is "on"? Haven't a clue, but you might check your ignition switch wires for a start...
  1. WTB: a running 1971 2.2 911T engine
    By rliberty in forum For Sale: 911 Parts
    Last Post: 03-26-2014, 06:09 AM
  2. FS: 901/01 Aluminum 2.0L Engine -- running
    By Auto*Legends in forum For Sale: 911 Parts
    Last Post: 11-07-2013, 05:28 AM
  3. 1969 911 - Both Head Lights just stop working-
    By 2008SPorsche in forum Technical Info
    Last Post: 10-14-2011, 09:38 PM
  4. FS: Parts from a 70T Running 2.2 Engine Carbs and 901
    By 76911S in forum For Sale: 911 Parts
    Last Post: 09-09-2010, 04:21 AM
  5. WTB Running 911E/S Spec Engine
    By 1972_911t in forum For Sale: 911 Parts
    Last Post: 09-17-2007, 03:53 PM
