Results 1 to 2 of 2
Thread: Re-do rear deck pad
    Re-do rear deck pad
    I would like to remove and recover the rear deck pad behind the rear seats (73 911). Does anyone know how to remove this part? Have any of you done this? Mine has warped in the area that comes in contact with the rear window. There was no engine pad and I think the heat from the engine may have caused the warping.
    1973 911S
    1967 Alfa GTV
    2002 Miata
    Dec 2002
    Birmingham, MI
    Not sure if you're talking about the vinyl trim or sound insulation.
    Unscrew vinyl trim pad from trim screws behind rear seatbacks/side panels and at strap holders on pkg shelf. !t should remove easily. Be careful as the substrate is fiberboard and can crease with too much force. You can order a replacement part if this is what you want to fix, or use the substrate as a template to cut and cover a new piece. You may be able to cut a new hard piece for just the shelf and rewrap with the original vinyl.
    If you want to remove the insulation pad, it should then pull out if you're lucky. The factory glued the pad on so you will likely need to scrape whats leftover from the metal. Some glue thinner or a heat gun helps here. I used an acrylic scraper which did not leave marks on the metal finish. Once you're down to metal, there are a variety of sound/heat insulation choices out there.
    BTW - Say a prayer now that you don't find rust from leaking seals / quarter windows!
    Hope this helps.
    Jared
    '73 911S #0793
    '69 912_ #0602
    Early S #0454
    RGruppe #0391
  1. FS: '67 Rear deck Lid #340
    By WP935 in forum For Sale: 911 Parts
    Last Post: 03-22-2014, 02:49 PM
  2. WTB: Rear deck lid
    By dave29 in forum For Sale: 911 Parts
    Last Post: 10-06-2013, 07:07 AM
  3. FS: Rear Deck Lid
    By Mudi in forum For Sale: 911 Parts
    Last Post: 10-17-2008, 07:05 AM
  4. value of AL deck lid and rear pan
    By bam914 in forum General Info
    Last Post: 05-04-2007, 02:59 AM
  5. WTB: rear deck metal section (below rear glass)
    By RS-GT in forum For Sale: 911 Parts
    Last Post: 04-25-2007, 06:15 PM
