Results 1 to 2 of 2
Thread: 68S oil temp&press.
    68S oil temp&press.
    What should be the correct oil temp in normal driving conditions, 80 to 95 F ambient. My car seems to run about 100 C. How hot is too hot on a 2.0L engine?
    At 80C my oil pressure runs about 1 druck for every 1000 rpm, but at 100 C and 6000rpm my oil pressure is 4.5 druck. Anything to worry about? This my first Porche just being cautious.
    1968 911S Soft Window Targa
    Your oil pressure sounds perfect, 1 bar per 1000 rpm, or 4 bar (60 psi at 4000 rpm). The oil temp can run up to and over 100C without problems, but I would suggest that if you are running in those high ambients a lot that you consider fitting a front oil coller
  1. FS: Sportomatic Oil Temp Press Gauge
    By letsrollbabe in forum For Sale: 911 Parts
    Last Post: 09-08-2017, 01:40 PM
  2. Replies: 6
    Last Post: 07-22-2014, 05:49 PM
  3. WTB: chrome/green oil gauge(press+temp) f. 911 swb
    By moito in forum For Sale: 911 Parts
    Last Post: 06-01-2013, 01:19 AM
  4. FS: Euro Temp/press oil gauge
    By OliveR in forum For Sale: 911 Parts
    Last Post: 10-21-2011, 12:17 AM
  5. Green faced oil temp/press gauge
    By Will 1967 in forum Technical Info
    Last Post: 03-17-2010, 01:04 AM
