Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: rebuild 901 vs. 915 conversion
  1. #21
    OK, now I am confused agian ....
    Hayden & Sherwood, maybe you guys can enlighten me. I have a later model car (a 1973.5 year) and I am trying to go backwards -- to put a 911 type tranny froma 1970-71 into my '73 (I like th shift pattern).
    I have both the longer 901 shift tube and the existing (shorter) 915 shift tube.
    Which one should I use when I install the 911/01 tranny?
    THANKS!
  2. #22
    Randy,
    In every case, the best choice is the tube that is correct for the transmission you are installing. The tube changes with the transmission - not the chassis.
    Use the longer 901 tube for the 901 / 911 transmission in the 73.5 chassis, if you use the 915 tube your coupler will make insufficient engagement in the end of the tube.
    Hayden
    Technical Director
    Windrush Evolutions Inc.
  1. 3.2 conversion into 71
    By Sundevil64 in forum Technical Info
    Last Post: 10-13-2013, 07:14 AM
  2. 3.2 Conversion ECU
    By CidTito in forum Technical Info
    Last Post: 07-28-2013, 03:47 AM
  3. Power brake conversion / de-conversion (1973 2.4E)
    By obrut in forum Technical Info
    Last Post: 12-13-2012, 02:18 AM
  4. 86 3.2 Conversion kit
    By jpnovak in forum For Sale: 911 Parts
    Last Post: 06-24-2011, 06:18 AM
  5. 2.7 conversion?
    By disfunction in forum Technical Info
    Last Post: 04-04-2004, 10:49 AM
