Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: What size ?
  1. #11
    Goldmember ttweed's Avatar
    La Jolla, CA
    Originally posted by Chuck Miller
    I have also read that W.O.W. '74-'76 Carreras and early 3 liter Turbos have 18mm rear sway bars.
    Just a "head's up"- the 18mm rear ARB from the early Turbos have a little bend in the middle to clear the 930 4-speed tranny. They aren't exactly the same as the 18mm bars from the '74-77 911S, but I think they would still work on an early car. I haven't tried one, though, I've always been able to find the straight 18mm bars at junkyards fairly easily for about $75. I'm using one now on my '67S, along with the 18mm front bar from the early Turbo (which is exactly the same as the early S through-the-body bar, except for the diameter.)
    On the '73 track car I am using a 19mm Weltmeister adjustable in the front and a 21mm fixed rear bar from the 3.2 Carrera, which requires a custom linkage for the droplinks to the trailing arm.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
  2. #12
    A tip for guys pawing through wrecked-em yard bars...take an open end wrench with you...18mm if looking for an 18mm bar, and so on. Instant, and accurate measuring.
  1. tire size rsr 73
    By gwilliams in forum Technical Info
    Last Post: 12-08-2011, 06:01 PM
  2. Header size for 67S ?
    By Peter Aziz in forum Technical Info
    Last Post: 04-05-2009, 05:58 AM
  3. What is the right size PMO for a 3.0 litre?
    Last Post: 09-23-2008, 07:40 AM
  4. 67S tire and size
    By mwilson3003 in forum Technical Info
    Last Post: 09-03-2007, 09:42 AM
  5. What size are these steelies?
    By garrege in forum General Info
    Last Post: 08-03-2007, 08:34 PM
