Thread: 67S rear spring plate bushings
    I changed my rear spring plate bushings on my 67 911S and ordered bushings going by the Weltmeister catlog in pelican parts and got inner bushings that do not fit properly I checked my factory book page SR31 shows 911S with chassis # past 305 101 S use the 69-76 inner bushing ( which is the same outer bushing from 65-89). So if you have a 67-68S you can order Neatrix bushings or any bushing that fits the 69-76 911 cars. Once again only non S 911 cars used the little inner bushing from 65-68. I hope this saves some one else time , Fritz
    I'm not the official greeter and welcoming committee, but welcome and thanks for the heads up. I might have fallen into that confusion at some point. I'm going thru suspension right now.
    Thanks for that. I will be doing this job soon on a 68S, which I guess is the same
    That helps me greatly as well...
    Thanks for that.
    Shawn.
    67 coupe roller
    99 M96 2.5 litre
    early911s reg 447
    R Gruppe 399
    Thanks for the welcome guys, this is my first early s I used to think that a s was just bolt on parts to a regular tub, in the 67-68 model years we have the interesting combination of short wheel base rear fenders and late model torsion tube. It really helps to have a place to get help like this, I am glad to add my "two bits"
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    Timely info!
    Thanks Fritz, I'll likely use this tidbit of info in the next month or so on my '68. Welcome aboard.
    RGruppe #183
  1. SWB spring plate /SC spring plates swap
    By smedley in forum Technical Info
    Last Post: 01-06-2014, 05:02 PM
  2. FS: New Cover Plates for Rear Torsion Bar/Spring Plate
    By Longballa in forum For Sale: 911 Parts
    Last Post: 12-20-2013, 11:22 PM
  3. Early or late spring plate bushings
    By Jerhofer in forum General Info
    Last Post: 10-04-2013, 06:31 PM
  4. Replies: 1
    Last Post: 09-25-2011, 09:11 PM
  5. Neatrix spring plate bushings glue?
    By Wolf Knierim in forum Technical Info
    Last Post: 01-14-2004, 12:13 AM
