Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 911S 2.4: Gas getting into the oil
  1. #11
    White smoke on deceleration might be oil getting past the new rings. There is a pretty good vacuum in the cyliders with the throttle closed and it will suck oil.
    Good that you are getting the MFI sorted. I'm sure the proper spray pattern will help ememsely. And the adjustments are there for your mid range and idle. I know, I did it myself. I/m not 100% happy, but I never am. It's 100% better though.
    Hopefully you find that the pump will come into proper adjustment and you can fne tune it on a dyno with a gas analyzer attached. The effort would be worth it to me for a new motor.
  2. #12
    Nov 2002
    Fremont, CA
    Car here yet?
  3. #13
    Just got back from the Green River in Utah last night (AWESOME PLACE!!!!!). I'll pick up the car on Monday.
    Chris Purpura @civilizedmisfit
    ___________
    Member #479
    Current Cars:
    1972 911T aka The "Civilized Misfit" Build
    See: https://www.excellence-mag.com/issue...vilized-misfit
    Miss February - EarlySRegistry 2023 Calendar
    1968 911S Ossi Blau/Beige Corduroy
    Past Cars:
    2019 911 Carrera GTS (sold, no regrets)
    73S - #1100 (restored and now somewhere in Europe)
    1997 993 Carrera 4S Black on Black (sold)
  4. #14
    Longhoods forever! silverc4s's Avatar
    Apr 2003
    Somewhere in Texas
    Here's another input for "sanity" as rightly suggested by Yopurp.
    My rebuilt 2.2 S engine, finished in 1995, first run in 2000, and run only sporadically since, has NEVER exhibited any sign of gas in the oil.
    Here are the specifics that might help narrow things.
    Pump rebuilt by Gus, incl injector check okay.
    Cold start mechanism has never been used.
    Roughly 2000 miles since car finished, Mobil One 15W-50 after first 100 miles with Valvoline HD 30.
    Some very short running, in garage only, maybe 8 to 10 times, combined with 5 long runs of 100 to 300 miles, and about 20 short runs of 5 to 20 miles, all for play purposes only.
    My guess is that if the internal pump is worn in the high pressure gas areas, that is the most likely cauyse of the problem with an otherwise good running engine.
    If the engine runs poorly, i.e. rich lean, smok of various colors, then Gus' comment re bad injector patterns may be likely.
    Disclaimer; I am a amateur, NOT an expert, so these are just my obsevations..YMMV
    Bill Conway, Early S Registry member #254
    1970 S, 2.2L Silvermetallic Coupe
    1973 T, 3.2L Black Carrera Targa
    1969 T, 2.4L Silvermetallic Targa
  5. #15
    Silver Bill,
    See my other post on General, but ended up doing all the adjustments myself with a fellow board member providing guidance and steady hand on the wrench. Car runs great, now need to go hammer the hills and seat those rings. Thanks to all for the advice.
    ___________
    Member #479
    Current Cars:
    Past Cars:
  1. Porsche 911S Owners Manual 1969 911S 2.0
    By 72targa in forum For Sale: 911 Parts
    Last Post: 03-19-2021, 07:29 PM
  2. Replies: 4
    Last Post: 03-03-2014, 11:45 PM
  3. Replies: 1
    Last Post: 08-04-2013, 03:48 AM
  4. Pending Russo & Steele Auctions of 1967 911S & 1969 911S
    By 72targa in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 01-25-2011, 11:11 AM
  5. Replies: 4
    Last Post: 12-24-2010, 03:12 PM
