Results 1 to 7 of 7
Thread: transmission questions
    Junior Member
    Apr 2004
    I found a 68 5-sp on ebay as a possible replacement for my 70 911E. Question, would this short wheel base transmission fit the long wheel base car?
    Suffolk, VA
    It should work. There may be a difference with the transaxle to chassis mount, and I know the clutches / flywheels are different. The 1970 box is a type 911 (upgraded type 901) with a push type clutch. If you use the earlier flywheel / clutch, then you will need a pull type clutch cable. It will be more difficult to convert the type 901 box to push type clutch because it will be missing the appropriate brackets on the box housing. Good Luck. Alternatively, you can use the type 901 internals in the type 911 box (this is what I would do).
    Citation F1000 on the way
    Other Early 911/912/914
    Junior Member
    Apr 2004
    Thanks. I want something that can be swaped without modification, or else, I will go w/ maybe 915 box. In the other words, I have not yet made up my mind.
    Thanks again.
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    I think that '68s had aluminum cases, as opposed to the mag case your '70 has. I think that the gearing may also be a little different.
    -Scott
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
    The drive flanges are different also.
    It will be a lot easier to find a good 911 box - ask me how I know...
    Junior Member
    Apr 2004
    How?
    Now I am asking, how?
    I spent many months trying to figure out how to put a 901 into my '73 and match the drive flanges. THe %*&^* who sold me the 901 said it would bolt right in. I finally gave up and bought a 911 type tranny.
    With the 901 you cannot swap the tranny's flanges with those of a 915 (internal splines differe) and the CV joints form the older cars will not fit the shafts on a '73 so you can't swap those either.
  1. WTB: Transmission carrier/mount for 911 (series) transmission
    By PeterM1965 in forum For Sale: 911 Parts
    Last Post: 07-02-2011, 09:16 PM
  2. A Few Questions
    By WillBeaumont in forum General Info
    Last Post: 01-27-2011, 08:26 AM
  3. Questions, questions and more questions...
    By vricardo in forum Technical Info
    Last Post: 01-01-2008, 09:41 AM
  4. Questions
    By porschefan in forum General Info
    Last Post: 08-08-2006, 09:48 AM
  5. 915 questions
    By Burzel55 in forum Technical Info
    Last Post: 06-01-2004, 07:58 PM
