Results 1 to 9 of 9
Thread: advice on oil change sockets
    joelrkaplan
    Guest
    ok, got all the paraphenlia required but have one question.....can any1 tell me what size hex sockets are needed for crankcase and reservoir on my 70T...TIA
    admin_old
    Guest
    10mm
    Hmmm...both my drain plugs take 19mm....NOT hex, just a 19mm wrench size. If memory serves, my '70 T did as well. What's up?
    Sherwood I think Joel is talk'n about the sump and tank plugs...
    That would be 19mm? ... my car is at home
    Thanks Paul
    joelrkaplan
    Guest
    gracias......
    Chuck, Joel may be running replacement plugs...when Ron Madio was here on his "big ride", we changed oil on his '77...then a 10mm hex was used, but tank only...sump was 19mm. Again "if memory serves". Joel, an afterthought...buy both! A guy can't have too many tools, right?
    joelrkaplan
    Guest
    I was going to say that when I peeked underneath the car I saw what I believe was hex heads on oil tank and case...I will check again but I think Sherman may be right in respect to my car......
    joelrkaplan
    Guest
    they could be replacement plugs; maybe po swapped them out......its my first time tackling job.......
    admin_old
    Guest
    I was not aware of a change in sump and tank plugs. If so, my apologies. My '69 has 10mm internal hex plugs. However, the tank plug was replaced years ago with a Fumoto ball valve. This avoids the dreaded "stuck plug" scenario that seems to occur on many cars.
    If it's an external hex plug, I'd think you could match it up with one of the metric sockets in your tool box? If so, use a six-point socket and a 1/2" drive breaker bar as it'll be tight.
    Sherwood
  1. How many odd 8mm sockets do you own?
    By loopie in forum Technical Info
    Last Post: 10-20-2012, 07:24 PM
  2. Spark Plug Sockets for 1964/65
    By IAA1963 in forum General Info
    Last Post: 02-10-2012, 01:28 AM
  3. White clips and sockets for dashboards
    By Fritter in forum Technical Info
    Last Post: 03-21-2008, 09:29 AM
  4. 1966 911 Headlight wiring sockets
    By red911 in forum Technical Info
    Last Post: 10-04-2005, 04:50 AM
  5. advice needed to jack up rear for oil change
    By joelrkaplan in forum Technical Info
    Last Post: 05-14-2004, 09:23 PM
