Results 1 to 4 of 4
Thread: Oil tank replacement
    Feb 2003
    Wanting to replace a damaged oil tank on a 1973 911 - have access to one from a 79 SC. Can I retrofit with this tank - any problems etc to be aware of.
    Thanks in advance.
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Early S Registry # 306
    Quote Originally Posted by 911kiwi
    Thanks in advance.
    The later oil tanks are different in a couple of ways.
    The connection for the S hose on the early cars is threaded, the later cars use a hose clamp. The oil filter console is slightly different as well.Best bet is to get another early oil tank. You should be able to pick on up for $150 US.
    95 968 cabriolet
    69 911e 3.0 transplant (sold)
    Feb 2003
    oil tank
    Thanks for the reply - will follow that advice.
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Kiwi,
    I have an oil tank I took out of a 75 that I am holding to convert my sporto to a 5 speed when/if the sporto ever goes south. It looks to be a bolt in replacement to me. Not sure if this helps.
    The capitalist roader.
    3 nearly identical silver 73's: MFI T Coupe, CIS Targa, S Coupe with sporto
  1. 85 liter plastic gas tank repair/replacement
    By NickP in forum Technical Info
    Last Post: 01-18-2012, 05:35 PM
  2. Replies: 1
    Last Post: 04-22-2010, 07:24 AM
  3. Plastic tank to trade for 100 liter steel tank
    By Rick Cabell in forum For Sale: 911 Parts
    Last Post: 04-12-2010, 09:13 AM
  4. FS - MFI AirBox/Throttle Stacks, Oil Tank, Vacuum Tank...
    By tgittens in forum For Sale: 911 Parts
    Last Post: 11-02-2009, 12:08 PM
  5. gas tank replacement on 73 E
    By cmcfaul in forum Technical Info
    Last Post: 10-05-2007, 07:19 AM
