Thread: '73S engine surging
    '73S engine surging
    My 2.4S has always had this surging problem between 2800-3200 rpm under a light load. Typically driving around town in 3rd gear. The motor accelerates fine from idle to redline. A friend with another '73 S experiences the same thing. Is this typical of these motors?
    The motor, mfi and throttle bodies have all been rebuilt. When JW set the motor up they plugged the distributor vacuum line, and the motor is set up to run a few degrees advanced at idle.
    My mechanic has adjusted the mfi a few times. The surging is still there, sometimes less, sometimes more.
    Any suggestions on what else to try?
    '73 S coupe
    You're in Seattle? You might give ROTHSPORT down in Tualatin, OR a ring. Gordon Ledbetter there really knows MFI. The downside? You might have to wait until after race season to get in...
    Mfi
    Chris' German Auto in Bellevue would be another strong candidate.
    However, I am with Paul. If you can hook up with Professor Ledbetter, the problem will be solved in a very timely fashion!
    Howard Lazarus
    Early S Registry #357
    RGruppe #181
    1971 911S Conda Green, Factory Airport Gears
    1972 Corsican Rose Love Fest
    Used to be in Seattle, now in San Francisco Bay Area.
    East bay MFI expert
    I have the guy for you.
    Peter Sorensen @ Porsche Restoration in Crockett, CA.
    (510)-787-2200.
    Howard Lazarus
    RGruppe #181
  1. Replies: 8
    Last Post: 09-01-2012, 06:47 PM
  2. Fleebay Engine: 1968 Porsche 911S Engine 901/02 Weber IDS 40 Carbs 911 S Motor
    By Doc72 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 08-31-2012, 08:09 AM
  3. Replies: 23
    Last Post: 08-30-2012, 07:01 PM
  4. Surging
    By Vic Elford in forum Technical Info
    Last Post: 12-30-2006, 08:04 AM
  5. Replies: 33
    Last Post: 11-02-2005, 04:13 PM
