Results 1 to 10 of 10
Thread: Will 205/55/15s fit a '68 911
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    Rookie question, I know, but...
    Are there clearance issues with 205/55/15s and deep sixs on this car? Inside? outside? I know that there is always some asymmetry in that this was never a critical concern to the maker since the stock tires at the time were so skinny.
    RGruppe #183
    Senior Member Homemade 911's Avatar
    Dec 2002
    China Lake - Third Rock From The Sun
    fitting tires & deep sixes...
    Jens
    A data point: I run 205/50/15s (Kumho Victo racers) on deep sixes all the way round on my '68, with a spacer on the rear. The car is lowered quite a bit, and yet I don't have any clearance issues. My thinking is that you simply wouldn't lower the car quite so much with the 55 height tire on it. If the car is stock height, you may want to lower it just enough to make the new tires look "just right" in the fender wells.
    With stock sheet metal, a 205 is about all you're gonna get in there anyway, without resorting to even the most minimal fender mods on the rear...a good number of the guys I race with have 225s on the rear with mod'd fenders.
    Hope this helps - good luck
    cheers
    Thom Kuby
    Aug 2003
    vahmont
    Thanks Thom. I'll lower it some but not as slammed as I would on my other cars. My thoughts eggs-ackley on the filling of the wheel wells.
    RGruppe #183
    Goldmember ttweed's Avatar
    La Jolla, CA
    Jens-
    I run 205/60-15s on 6s for the street and 205/50s on 7s for the track on my '67S. The 7s require rolling the fender lips, the 6s don't. You should be fine with 55 series. The only clearance issue is on the inside front wheel well where you will rub the back of the tire on full steering lock, but his only happens at low speed when doing a tight U-turn. My car is lowered slightly but not slammed like a race car.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Aug 2003
    vahmont
    Thanks Tom, if that's as bad as it gets, then it's no worries for me. My only real thought was if I get some rubbing at full chat with a risk of cutting a tire. I'll forge ahead!
    RGruppe #183
    I have the same tire/wheel combos that TomT has and have the same observations. The 205/50s have a very small diameter. The 55 should help.
    Quote Originally Posted by ttweed
    Jens-
    TT
    Do you have any speedo discrepancies with the 205/60-15? I need new tires now, and want make sure I don't have any problems.
    '71 911S Targa
    Aug 2003
    vahmont
    I used to have a link to the Miata tire calculator that was really useful for just such figurin', but my link doesn't work any more. You could enter in your original factory tire size and then enter any other tire to compare the dimensions of the different sizes. Holding a close diameters would maintain speedo function. Does anyone have the url to such a calculator?
    RGruppe #183
    I found another one...
    Turbo Saab Tire Calc
    '71 911S Targa
    Apr 2003
    Portland, OR
    Quote Originally Posted by Jens
    Jens,
    Here you go: http://www.miata.net/garage/tirecalc.html.
    FWIW, I have 205/60-15's on my '73 (6" cookie cutters) and the speedo has pretty good agreement with the speedgun at the track.
    Harry
    Member #789
    2009 MB C300
