Thread: Can't Select Any Gear!
    More than Original
    Jun 2004
    SoCal
    First off the car is a Sportomatic.
    OK, I went out last night to replicate my starter issue (intermittent starting worked fine 9/10 times) and could not replicate the issue. So I decided to go for a drive, but could not get it in to any gear. It feels like something is blocking the selection of gears. It wasn't even grinding when I pulled with some force, except first which has been normal lately and unneeded with a Sporto which launches fine in 2nd. After some revving and pulling I did get it into third once with a slight grind. I shut her down and was able to get in all gears with the engine off.
    This problem arose out of no where, last time I drove the car it ran great. I just rebuilt the carbs and replaced all sporto vac lines, I doubt they would develop a leak just sitting there. As I said before there has been some grinding lately with 1st and also reverse but all else was good. I did check the oil level since the torque converter shares engine oil and it was within the marks on the stick I added a little anyways and it did not help. Would being low on trans fluid create this problem, or is the clutch wet? Could the clutch adjustment be off?
    I am lost when it comes to internal trans operations, I do however have the sporto operations figured out.
    Any reccomendations for a shop to take it to in OC (Andial $, Haus of Perf, etc.) this will be a first time I have taken in the car to a mechanic? I do all my own work but don't know much about transmissions.
    Bret Davis
    1968 911L
    Sounds like a manual transmission with a clutch engagment problem. I am not a sporto expert, but it does not sound internal.
    Nov 2003
    Santa Monica CA
    select any gear
    for orange co., I would check out Scott,s Independent inc. in Anaheim 714-634-2027. He has been around a long time. Also Ausse Brothers in Orange c0.
  1. Replies: 2
    Last Post: 10-12-2013, 06:00 PM
  2. WTB: B 1st gear and GA 2nd gear for 901 transmission.
    By RSwannabe in forum For Sale: 911 Parts
    Last Post: 01-20-2013, 11:25 PM
  3. DFG, Select special steel, Selected steel
    By preS in forum General Info
    Last Post: 12-28-2010, 01:16 PM
  4. WTB gear sets for 911/01 gear box
    By 60surfer in forum For Sale: 911 Parts
    Last Post: 05-31-2009, 10:27 AM
  5. FS: 901 'S' gear (4th/5th)
    By kenikh in forum For Sale: 911 Parts
    Last Post: 10-21-2008, 11:00 AM
