Results 1 to 8 of 8
Thread: indicator seals - quick question
    Jul 2004
    Sydney, Australia
    Hi
    I'm replacing the indicator lenses and seals on a 69-73 car.
    On the seals:
    - what glue is best - any thoughts
    - do I stick them onto the lens, or onto the indicator unit ?
    - the moulding on the seal is slighly different if i turn it over - is it obvious which way to stick it ?? (!!)
    would appreciate any advice ..
    Paul
    1969 ex-South African RHD Tangerine 911T . 1970 ex-Southern Californian LHD Conda 911T 1955 Series 1 86" Land Rover (original Australian CKD … very slowly re-building) 1987 W124 230e
    (long term paid up member)
    Apr 2003
    Portland, OR
    Quote Originally Posted by pgxif
    Hi
    On the seals:
    I hate when I go to replace a bulb and tear the seal cuz some fool glued it down.
    Personally, I would not use anything. I expect the gasket to conform to the surfaces and seal (even the Brits usually got that right on my Spitfire ... as long as there was no motor oil nearby....). But lets see what the true experts say.
    Harry
    Member #789
    2009 MB C300
    Jun 2004
    Zurich
    I agree. With three proper screws in place the seal should stay where wou put it.
    Maybe they should stay in place but they were glued at the factory with some form of contact adhesive to the body of the indicator not the lens.
    I have put new ones in using a modern contact adhesive and the have been fine.
    Clyde Boyer
    I use Evostik contact adhesive, or clear silicone bathroom sealant, which lets you take the seal off again more easily
    Jan 2003
    UK
    If you coat the mating surface with a thin smear of Vaseline (petroleum jelly), it stops the lens sticking to the seal & damaging it when the lens is subsequently removed.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Jul 2004
    Sydney, Australia
    Many thanks guys, will get on with the job ...
    cheers
    Paul
    Hmmm...some enterprising soul needs to make these out of silicone, so they are reusable...like the valve cover seals now available.
  1. quick tire question
    By Rwm514 in forum Technical Info
    Last Post: 04-14-2011, 03:17 PM
  2. Esses: Quick question
    By Bummler in forum General Info
    Last Post: 10-10-2007, 10:17 AM
  3. 911 front indicator ID question
    By lisa_spyder in forum Technical Info
    Last Post: 10-12-2006, 04:14 AM
  4. Indicator Lamp Question
    By 2POINT7 in forum General Info
    Last Post: 10-05-2005, 11:29 PM
