Thread: A little strut help please
    Struts? Whats what?
    I just bought a set of "S" brakes for my 1972 "T" and boy I am happy, but I have one proublem. "S" brake s will not fit in the 3" spacing that are "T"s
    So I need to Look for 3.5" spacing right.
    Well what are my options "S" struts or "SC" correct?
    ANd what are the difference between Koni and Bilsteins?
    Do they both have 3.5" spacing and are just different brands
    or do the two have different set ups.
    So what do I need to make these nice "S" brake that I am very excited about work?
    Also if you have any of these parts for sale please let me know
    Thanks for the help and check out my project if you get a chance
    http://www.356-911.com/911restogall...ekoxford911.htm
    __________________
    1972 911t Coupe(being Restored)
    1973 911t Targa(parts Car)
    2001 Audi A4 Quattro
    2004 Ford F150
    Feb 2003
    Corpus Christi, Texas
    You'll need either an original Koni strut, or a later A or Carrera strut. Koni, Bilstein and Boge all used the 3.5" spacing at points in time. The A caliper started appearing in 1975 or so. If you get a Bilstein strut you're locked into using a Bilstein insert. If you get a Koni strut, you're locked into using a Koni insert. If you use a Boge strut, you can use Boge, Koni or Bilstein inserts.
    Jason Burkett
    Paragon Products
    www.paragon-products.com
    Early 911S Registry #428
    R Gruppe #375
    1973 911S
    1974 914 Limited Ed. Blk/Yellow
    1993 968 Turbo RS
    1967 Shelby GT500
    2022 VW GTI, Daily Driver
    Suffolk, VA
    With brakes, especially for 911T's, there are other options. Wilwood makes some wonderful four piston aluminum calipers which probably sell for less than you paid for the used 911S aluminum ones, are new, and are better. In the front of our old cars, the shocks are inserts which screw inside the struts, and the thread is different between the Koni S and the Boge strut. If I were in your place, I'd sell the S calipers, purchase a set of Wilwoods and purchase new Konis for the Boge strut. In my opinion, the brakes on the 1972 T are more than adequate, but you will see quite an improvement in handling with new front shock inserts. Also consider new rear Konis. Since the rear is so heavy relative to the front, these cars need more rebound damping, and the adjustable Konis will provide that.
    Citation F1000 on the way
    Other Early 911/912/914
  1. Where to buy ST/RSR strut bar?
    By ETW in forum Technical Info
    Last Post: 09-16-2013, 11:59 AM
  2. WTB Rt. Boge strut
    By Bernie B in forum For Sale: 911 Parts
    Last Post: 04-11-2012, 07:58 AM
  3. FS; Koni strut inserts, pn 86-1647 for Boge strut housings
    By m1franck in forum For Sale: 911 Parts
    Last Post: 03-08-2010, 10:19 AM
  4. SWB Strut Checker!
    By 304065 in forum Technical Info
    Last Post: 06-01-2009, 08:48 PM
  5. Best strut brace?
    By dhopkins in forum General Info
    Last Post: 08-11-2006, 11:49 AM
