Thread: unisyn vs. synchrometer
    Apr 2004
    I am going to need to balance my carbs. This will be a first. Which should I use ? Is one easier to deal with or more precise?
    Thanks;
    Du must schwein haben
    901/05 #305701
    Bultaco Metralla 62 M8
    1968 BMW R69S
    Early911SReg #606
    Apr 2003
    Portland, OR
    I have never done this but I have heard the Synchrometer is easier to use and more repeatable.
    If you need one, I have one on my shelf for the 912 I used to own but never had a chance to tune (school bus vs car). I'd be glad to share. E-mail me privately.
    Harry
    Member #789
    2009 MB C300
    I agree w/Harry - The theory of operation of the Uni-Syn _ought_ to be more accurate but it just doesn't seem to be as repeatable.
    There are other ways to measure air flow BTW.
    You might want to hook up 4 U-tubes of water and build manometer bank. That's what the old Ferrarri mechanics did -- very impressive looking, and easy to read - you just scan across the line and if they are not lined up, you adjust.
    I should have an old vane anemometer around here somewhere and keep meaning to find it and hook it up.
    I also like the ease of use of the synchrometer, however, the rubber cone of my synchrometer does not fit down inside the velocity stacks. I have to press down on it so that it seals on the upper lip of the stacks. It still works but doesn't seem right. Maybe there is a model of synchrometer where the sealing cone sits down inside the stacks?
    Wolfgang
  1. FS: Synchrometer Type SK
    By 72targa in forum For Sale: 911 Parts
    Last Post: 12-13-2007, 06:49 PM
