Results 1 to 7 of 7
Thread: Underbody help
    Jun 2004
    Zurich
    Underbody help
    Can anyone tell me what a 1970 T originally had on the underbody (i.e. paint, PVC spray, etc)? Was it a 'pebble' finish painted white or body colour? My car has been sprayed at some point with stone guard. Underneath it looks like it may have been white or red... Any thoughts on how to proceed are appreciated.
    You can see a bit of the problem in this photo:
    Thanks for any help and advice!
    Early S Reg #675
    Mine is from 03/70 and has a pebble finish everywhere, underneath and in the wheel wells. The floor is perfect with one dime sized piece missing and the layers revealed around the hole appear to be a very thin layer of white against the bare metal, probably no more than a primer or etcher, and black topcoat. The wheel wells had taken a lot more direct rock hits in 35 years so I decided to refinish them recently. You can see the pebble finish here -
    John Gray
    70 old air
    86 middle air
    95 new air
    The underneath was sprayed body color beginning with the 1973 models. Prior to that, black...
    Jun 2004
    Zurich
    Can anyone confirm that? This car is very original and shows no signs of a black underbody spray (aside from aforementioned black overspray)...
    Early S Reg #675
    Then maybe yours was built before February 1970. That's the reason I mentioned mine was built in March - I knew they had made a change around in there somewhere.
    I dug out the factory supplemental body manual - here are the pertinent pages -
    John Gray
    70 old air
    86 middle air
    95 new air
    And the one other page there that makes mention -
    John Gray
    70 old air
    86 middle air
    95 new air
    For what it is worth, Wurth Products makes an outstanding spray on undercoating. I really recommend it
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
  1. WTB: Wurth Underbody Seal - Beige
    By mac73s in forum For Sale: 911 Parts
    Last Post: 10-07-2013, 12:50 PM
  2. Underbody color on a '67
    By kilodawg in forum Technical Info
    Last Post: 11-19-2008, 06:38 PM
  3. painting underbody of 70 car
    By gary basil in forum Technical Info
    Last Post: 02-24-2008, 09:28 PM
  4. Help with Underbody sealer- Wurth
    By Paul Hatfield in forum Technical Info
    Last Post: 10-27-2005, 10:39 AM
  5. 71 911S Correct color for underbody et all
    By charlestonius in forum Technical Info
    Last Post: 04-29-2004, 02:39 PM
