Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Fog lamp wiring ????
    I just installed a fog lamp switch so that I could finally get my through the grill lamps working. I dont have a wiring diagram for the fog lamp circuit however. Can anyone help out?
    On the back of the switch I have terminals 1,2,3 and k
    Is there a relay for the fog lamps? part #?
    Thanks for any help =)
    Dave
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    Jul 2003
    Santa Cruz, CA
    Hi Dave,
    Yeah, fog relay listed. Part number 911.615.109.01. It's a general purpose relay used in several applications. On your relay panel to the left of your fuse panel there are 4 positions for the circular relays. Position one is at the bottom ending with position 4 at the top. Position 1 is horn, Position 2,3,4 are configurable depending on options. You could run position 2 for fogs, 3 for driving lights and 4 for air conditioner if you have all of those options.
    Now, is it needed? As far as wiring, my diagrams show direct wiring to the fogs from the switch through the fuse without a relay. I'm assuming the relay would be needed for the Euro fogs cause I think those ran 55W not the US 35W. Good idea running relays no matter the wattage. Saves the switches from the higher current. The bad news is my wiring does not show terminal numbers. I'll draw up a quick diagram sice I don't have a scanner.
    I'm going out on a limb and judging from other switch wiring that shows terminal numbers (of Course ) that the K terminal is the common (chassis ground) and will have two brown wire attachments at the same spade. Two of the other terminals will have a jumper from one spade to another. This is the load side of the switch which in turn powers the fogs through the fuse and the indicator light. The other spade is the hot lead which is activated through the main headlamp switch. I'll try and draw it up and attach it as a picture.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Cool! Thanks man! I am pretty good diagnosing existing wiring issues but I have trouble when forced to start from scratch.
    Any help you can give is mucho appreciated.
    Dave
    10 sec 67 VW
    Jul 2003
    Santa Cruz, CA
    Let's see if this works
    quick and dirty
    Attached Files Attached Files
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Jul 2003
    Santa Cruz, CA
    I'll try it in another format. Ahhhh much better.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Wouldnt the indicater light be linked to one of the hot leads? Or does it already have power and the ground connection completes the circuit?
    10 sec 67 VW
    Jul 2003
    Santa Cruz, CA
    Well if you look at the drawing the hot comes from fuse 6. If you imagine the switch pulling down the cross line at the top bridges between the fuse 6 line over to the fuse 5 line. This is now the hot to the fogs. At that same terminal the jumper that runs down to the indicater makes the circuit to the indicator bulb. The negative or chassis is always connected to the bulb. Only the hot gets switched.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    I am going through this right now too...
    I have removed my factory fogs and am proposing to use the existing switch and wiring for upgrading to through the grill (ttg) driving lights. I have been informed that an additional relay is required to comply with the increased amperage requirements.
    I am electricaly challenged and will refer to others for this modification...but, Michael knows his stuff.
    I even have a full set of factory shop manuals with electrical diagrams that I can send/post but not interpret...if that helps.
    Shawn.
    edit: damn you guys are quick!
    67 coupe roller
    99 M96 2.5 litre
    early911s reg 447
    R Gruppe 399
    Ahhh, I see! Now, what if I used a factory relay?
    BTW, check your PM's regarding the NOS switch you wanted.
    10 sec 67 VW
    Jul 2003
    Santa Cruz, CA
    I edited the drawing as I had one wire out of place but the result is the same. The jumper for the indicator light is external to the switch from spade to spade.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  1. Need Fog Lamp Switch Wiring Help
    By gsjohnson in forum Technical Info
    Last Post: 05-22-2017, 05:16 AM
  2. Fog Lamp Lenses for 71 S
    By beatnick65 in forum Technical Info
    Last Post: 04-23-2013, 01:54 PM
  3. Fog Lamp wiring???
    By kllr901 in forum Technical Info
    Last Post: 01-13-2011, 07:36 PM
  4. Single TTG lamp
    Last Post: 05-11-2009, 05:53 PM
