I want to have a new paint tag made up for the '71 Targa. The color is Signal orange, can someone confirm that the paint code for a '71 Targa is 1410? I think the paint code for a coupe is 1414. Thanks.
Brian
'71T
R Gruppe #299
That's what Dr. B. Johnson's book says. Code 116. Another book I have says 1414 and doesn't distinguish between coupe and Targa.
Brian,
You are right, the paint code is 116 and the paint # for a targa is 1410
Cheers,
The Red Book says 'Paint Code' is 1410/1414 (Targa/Coupe) and 'colour chart number' is 116...
Early S Reg #675
Thanks guys for the confirmation. Morgan's book doesn't list the Targa/Coupe differences. Does anyone know where I could get it stamped and what fasteners were originally used to put the tag on with? Thanks again.
Brian
'71T
R Gruppe #299
Brian,
I would think a machine shop would have the stamps you could use on your blank plate.
For ataching, there was a thread here (or maybe Pelican) about appropriate fasteners for the plate. I think it leads to McMaster Carr (www.mcmaster.com).
Harry
Member #789
2009 MB C300
My bodywork guy tells me the tags are attached using a square section tack with a domed head
Here's the thread at Pelican I was thinking of:
http://forums.pelicanparts.com/showt...ht=paint+plate
Harry
Member #789
2009 MB C300
Thanks guys for the info. Looks like the fasteners are on page 3137 of the McMasters Catalog. Do you know what size is correct? I don't have any used fasteners to measure.
Drive screws in McMasters
Brian
'71T
R Gruppe #299
Do you have the holes in your car? If so, you can use a drill to meaure the hole size.Originally Posted by fryardds
Harry
Member #789
2009 MB C300
