Thread: 118 fog lights
    118 fog lights
    What parts are required to properly install through the grill 118 fogs on a 73 targa? Do they require a relay? What is the proper location of the dash switch? What is the correct process?
    Thanks in advance,
    356Robo
    64 C Coupe
    73S Targa, soon
    I'm interested, too. What is the proper gauge of wire to use? What is the proper dash switch to use? Where should you connect into the power?
    Will this work as the switch?:
    Switch
    Is there a wiring harness available?
    Senior Member 911kiwi's Avatar
    Feb 2003
    Auckland, New Zealand. And Los Angeles, USA.
    Foglight switch
    The wiring should already be in place - ex factory. Look under the left & right fenders near the healights - there should be a grey & a brown wire on each side.
    The switch is located between the rear demister switch & the cig lighter & looks like the demister switch with a light logo in the rubber knob surround & the colour of the light behind the logo (which illuinates of course) is yellow for 69 & 70 & green for late 70 -73. Unfortunately these are not that easy or cheap to find.
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Early S Registry # 306
  1. were can i buy euro side lights and back lights
    By ds58 in forum Technical Info
    Last Post: 09-30-2012, 08:11 PM
  2. Replies: 2
    Last Post: 02-02-2012, 11:02 AM
  3. Replies: 12
    Last Post: 01-26-2010, 05:30 AM
  4. Replies: 10
    Last Post: 10-18-2006, 02:04 PM
