Thread: electrical problem
    electrical problem
    hello all, got a problem with my 71 911t. i'm trying to resurrect this car after long storage. put in new batts and tried to start but nothing at all. guages or lights etc would not work either until i jiggled a few noticable wires under the ignition switch. now i have everything it seems but the starter and the horn. also, when i use the directionals both arrows light up. assuming it's the ignition switch, does that come out easy or do i have to peer under the dash?
    any ideas appreciated
    steve
    57t1
    71 911
    84 carrera
    soon a 911s
    Senior Member WHCJr72S's Avatar
    Bay Area
    Steve:
    It sounds like you have ground problems. Check and clean varrious ground studs and connectors. On early Porsches the ground wires are brown. The two turn signal lamps being light is a ground problem.
    Bill Cilker, Jr.
    Gold 72 911S
    31 Ford Model A
    PCA, Early S Registry (#98) & RGruppe (#272)
    Rotarian
    Jun 2004
    Zurich
    I read that 90% of Porsche electrical problems are from a bad ground. Start from scratch, make sure all the contacts are perfectly clean, and you will save yourself (and future owners) a lot of headache.
    Early S Reg #675
    Suffolk, VA
    A typical problem on these cars is the ground strap between the transaxle and the chassis, under the car. The ends must be tight, rust and oil free to get a good contact.
    Citation F1000 on the way
    Other Early 911/912/914
    Quote Originally Posted by roblav
    Glad you brought this up...I know a guy who cared enough to install double ground straps...
  1. An electrical why
    By yale in forum Technical Info
    Last Post: 04-03-2012, 02:30 PM
  2. Electrical Help Please
    By 67SWT in forum Technical Info
    Last Post: 05-04-2010, 05:26 AM
  3. Electrical problem
    By bburcha in forum Technical Info
    Last Post: 03-31-2006, 01:23 PM
  4. Electrical
    By Lee in forum Technical Info
    Last Post: 09-28-2005, 08:30 AM
  5. Replies: 4
    Last Post: 02-10-2005, 08:51 AM
