Results 1 to 2 of 2
Thread: trying to decipher an engine number
    hello, got these numbers on the right hand side of the fan. 901-01 2361 and *902461* can anyone give me some info?
    appreciated
    steve
    Goldmember ttweed's Avatar
    La Jolla, CA
    That looks to be a Type 901/01 from later 1965 production. Originally 1991cc w/ Solex carbs, 130 DIN HP, 9.0:1 compression ratio. Correct for chassis numbers 300236-303390. Check this table.
    After so many years, unless you know the history of the engine, there is no telling how it may have been rebuilt in the past. The numbers stamped on the case may have no bearing on the internal components anymore. The early aluminum cases are a favorite for hotrodders.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
  1. Decipher a COA
    By Ant22 in forum Technical Info
    Last Post: 11-04-2012, 03:52 PM
  2. Steel wheel decipher????
    By Davz912/911 in forum Technical Info
    Last Post: 08-09-2008, 10:44 AM
  3. 2.4S Engine number
    By CHK in forum Technical Info
    Last Post: 12-09-2007, 02:17 PM
  4. Engine Number
    By mwilson3003 in forum Technical Info
    Last Post: 08-03-2007, 02:29 PM
  5. Engine number
    By hdavis in forum General Info
    Last Post: 03-11-2004, 09:16 AM
