Thread: 1973 Vin Number Help!
    Hey, I'm looking into buying a 73 911S and I found one, and got the engine and chassis numbers. I want to know if they match. How do I figure that out. are there any links to websites that can give me that date? I have found links that show the vin numbers, but how about the engine numbers? When buying a car out of your own state, can you guys give me some pointers in buying a 911? Thanks.
    - VInce
    Jan 2003
    NW Indiana
    Another possibility is join the Early S Registry (shameless plug) and you will receive a list of early cars and engine #s and compare them to the ones on the car you are looking at. That is how I knew our '71 was #s matching. Another member had the consecutive VIN # to ours and the engine # was two #s different then ours.
    Tom is correct the best way is to obtain a Certificate of Authenticity from PCNA.
    Brian
    '71T
    R Gruppe #299
    Dec 2002
    Birmingham, MI
    Vince,
    You may know this, but the VIN should have a <33> in it if it's a 73S.
    First 3 is for the model year (73) and 2nd is the S designation. 2 for an E - and a 1 for a T.
    Like this:
    91133XXXXX
    The number after the 2nd 3 will be a <0> for a coupe and a <1> for a targa.
    If you PM me the engine number, I can at least tell you if it's correct for the model year. Good advice from Brian on comparing the sequence to the Registry list.
    Jared
    '73 911S #0793
    '69 912_ #0602
    Early S #0454
    RGruppe #0391
    Is the Certificate of Authenticity from PCNA the same as a Kardex? If so, PCNA seems over priced. $110 from PCNA compared to a Kardex for $70 that I found online from a Porsche Dealer in Florida, the form was on their website.
    http://suncoastporsche.com/kardex/
    Is there a difference? If so, what is it?
    I've got 9112300333 with a 911/53 engine but I'd like to confirm the engine serial number as original, as well.
  1. 1973 2.4S - build date / chassis number ?
    By james in forum General Info
    Last Post: 09-11-2019, 01:13 PM
  2. 1973 rs chassis number database
    By pht9 in forum General Info
    Last Post: 12-03-2011, 11:27 AM
  3. Replies: 7
    Last Post: 01-10-2011, 12:10 PM
  4. Production Number (aka kneepad number) decoding?
    By PSportoVeloce in forum General Info
    Last Post: 07-29-2006, 07:51 PM
  5. This was a 1973 911S Coupe (Serial number 0036)
    By 72targa in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 11-10-2005, 10:15 PM
