Can anybody tell me if running deep 6's with 185/70x15 tires on an "O" series is possible or not (straight line but also with max turning)
thx
thx
I've seen a 68'L with 7x15's on all four corners so I can't imagine why you couldn't put on deep sixes. I have no first hand experience however.
Bobby
71' Olive 2.2E Targa / Early S #491
I've always considered the glass to be half full...that is until I reached middle age and realized that it is actually half empty.
I had a set of those mounted on 4.5J X 15" factory steel wheels. They came that way with my 67 car. I removed them promptly.
Deep six's with 195/65 R15 tires are a perfect fit for swb cars. Well any early car. I would imagine that 185/70 series would fit as well.
I have 205/60 R15's on my deep six's. I know many guys that run the same, and larger on thier (mostly) unmolested early cars...from 67 to 73!
I am a period correct only junkie when it comes to early porsche stuff. But, good tires are a life safety issue. Performance too.
shawn.
edit: to add "Well any early car."
67 coupe roller
99 M96 2.5 litre
early911s reg 447
R Gruppe 399
Originally Posted by turfclubroad
No problem at all although you'll likely need to add a touch more negative camber for tire clearance, depending on the brand of tire you are using.
Steve Weiner
Rennsport Systems
Portland Oregon
503.244.0990
I have thought about changing my 4.5"/165 set on my '66 but my "period correct" genes have been controlling to this point. However, I have always thought the fender flares of the '69 cars were to accomodate the 6"/185/70 combo. The widest factory wheel on the non-flared cars was the 5.5" in '68.
Jim Chambers
1966 912
I have both the original 4.5" steel rims with 165R15 tires and 195/65VR15s on 5.5" Fuchs for my 1965. The 195/65 tires take one spacer (roughly 5mm) each. There's no fender clearance problem.Originally Posted by Porsche Rescue
It would be a crime to get rid of your original wheels at this point, but there's no reason you can't add another set!
Jim Alton
Torrance, CA
Early 911S Registry # 237
1965 Porsche 911 coupe
1958 Porsche 356A cabriolet
With max. steering lock, the larger tires on 6" wheels will rub the tread shoulder on the inside of the wheel well on the SWB cars. This only happens at very low speeds (in parking situations, etc.) so it is not a damaging situation, unless you are concerned about a short arc rubbed in your undercoating. Straight line, there is no problem.Originally Posted by turfclubroad
I run 205/60-15s on 6" wheels for the street and 205/50-15s on 7" wheels for autox on my '67S with stock fenders. The lips had to be rolled for the 7s, and I have a more agressive alignment, with 1.5 degrees negative camber dialed in F&R.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
PCA National DE Instructor
Read my surf novel!
TTWEED,
Are the 7s that you mounted on the rear, the 7Rs as in 911.361.012.05 or the normal 7s as in 911.361.020.41?
If you mounted the normal 7s, then is it possible to go to a plus one setup with 7 x 16s? Assuming the lip is rolled and fender slightly massaged out.
Also, what is the big deal about deep 6 wheels? I thought there was only one offset in the 6 wheels, as in 911.361.012.06. So, no need to call them 'deep' or 'deep dish' as there was only one anyway. Am I wrong?
School me...
Tenzin
Offset/width on all the 6x15's is in fact the same. Difference between early "deep" wheel and later (sometime in '71 I think) is in the design of the center web which causes the early wheel to appear to be wider. The difference is cosmetic. The later wheel had the so-called "safety bead" which was intended to keep the tire on in case of a blow out. The early wheel's design requires mounting tires from the rear of the wheel.
Jim Chambers
1966 912
I had 7 inch phone dials on the rear of my 67 with 195 /15's and though I don't miss the look of them the performance diff I REALLY miss.
Du must schwein haben
901/05 #305701
Bultaco Metralla 62 M8
1968 BMW R69S
Early911SReg #606
