Results 1 to 2 of 2
Thread: Tach Question
    Tach Question
    Greetings all,
    I'm curious. What should the correct redline be for a 2.7 engine (circa '77 - S cams with mildly ported heads and Webers)? I'm running the original tach in my 71 and, although I know it's not redline, the engine 'feels' like 5000 on the 71 tach is the sweet spot. The problem I'm having is not being clear on whether or not my 71 tach is calling it like it really is or if the engine's rpms are higher than the tach is showing.
    Signed...confused in Canada
    Paul Schooley
    S Reg #863
    R Gruppe #330
    Goldmember ttweed's Avatar
    La Jolla, CA
    Quote Originally Posted by Paul Schooley
    Paul-
    What makes you think the tach is not indicating correct RPMs? 5,000RPM may feel sweet as it could be your torque peak, depending on the setup on the Webers, but the engine with S cams should be able to rev to 7,000-7300 safely. Your tach should be getting the signal from your CD box, and there's not much to go wrong there.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
  1. NOS 68-69 S Tach ($400)
    By kentf14 in forum For Sale: 911 Parts
    Last Post: 07-28-2012, 06:17 AM
  2. 10,000 tach i.d. question
    By cosley in forum Technical Info
    Last Post: 03-25-2011, 12:05 PM
  3. MSD and tach ? for 66'
    By JHunter in forum Technical Info
    Last Post: 08-11-2007, 07:33 AM
  4. 69 S NOS Tach
    By rick2 in forum For Sale: 911 Parts
    Last Post: 07-19-2005, 11:46 AM
  5. MSD w/ Tach Adapter - But Still no Tach reading?
    By gruen911 in forum Technical Info
    Last Post: 07-14-2005, 12:39 PM
