Will a 15x7 minilite wheels fit a early 1971 911T with no problems?
I plan to use 205/55 tires.
thanks for your replies
I believe 7" would be a problem, however my 6.5" with 195X60 fit just fine!!
7s will fit fine with the right offset, as answered in your PP thread on this subject. You need to specify whether you are using them in front or back to determine the necessary offset.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
PCA National DE Instructor
Read my surf novel!
sweetE
can you please post or email me a pic of your car with 15x6.5 minilite wheels.
thank you
This is not a vcery good picture - the wheels are on my 76 912E daily beater & I've also had them on my 71 911E.
This one's not mine, but I spotted it at Road Atlanta a few years back.
Tom Morgan
Charlotte, NC
'18 Carrera T - R #368, S #692
1973 Giulia Super 1.3
This one is not mine either, but may be what you are looking for:
Thank you for all your reponses
looks good, my main concern is can I use 15x7 minilite on the rear?
will i have to roll the fender lips if i use 205/55 tires and just lower the car a little bit?
will there be any rubbing in the inside wheel wells?
i know according to minilite 15x6 or 15x6.5 is no problem to use.
As stated elsewhere, clearance with 7" wheels at the back can be accomplished. There seems to be enough variance from car to car that your question probably can't be conclusively answered. Usually, a spacer must be used with R wheels to avoid rubbing on the inside. If you ordered your Minilites with R offset, you would have the ability to select spacers that centered the wheel in the available wheel well space. Alternatively, perhaps you could experiment with your existing wheels to determine what offset would work best for your car. In general, it seems like 205s wold be no problem given the right amount of offset.
Early S Registry 1047
’15 VW GTI
'70 911E, Sold
'56 Cliff May Prefab
My '71 911 right now is equipped with its original 14" fuch wheels, this is why iam looking for a set of 15x6 fuch or go with minilites.
