Thread: Rebuilt Oil Pump?
    Rebuilt Oil Pump?
    I am getting ready to do the lower end on my 67S, Can 911 oil pumps be rebuilt succesfully? and who should do it? Who does good 911 engine machine work?
    Apr 2003
    Portland, OR
    Fritz,
    You might want to visit a few of the Air Cooled Porsche specialty shops in your area and ask who they use for machine work. Also, the local PCA chapter may be able to provide a few referrals.
    Harry
    Member #789
    2009 MB C300
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    I don't think that it is customary to rebuild 911 oil pumps. Instead, you might want to consider using a late-style pump (after '77) which features a larger pressure side and smaller scavenge side. Along with a modification to the oil pressure bypass system this will result in less oil in the crankcase along with better oil pressure. Wayne Dempsey's book, as well as Anderson's, deals with these issues extensively.
    -Scott
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
    Hi:
    Oil pumps cannot be rebuilt as there are no parts available to rebuild them,...
    When their internal parts become worn, scored, or otherwise damaged where they lose efficiency, replacement is the only option.
    As indicated above, a later oil pump is a very good and worthwhile upgrade to improve oil pressure and help reduce oil temperature due to better scavenging.
    One cannot buy the late 2.7 or SC oil pumps any longer so your only choice for these smaller pumps is the Carrera one. The case must be modified to use them and most knowledgeable Porsche machine shops can do this.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Thanks for the help, I really apreceated the tid bit about not being able to buy parts for the pumps that kinda sealed it, I went with a late pump. Fritz
  1. FS: Rebuilt MFI electric fuel pump
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 05-07-2013, 03:42 PM
  2. Bosch 2.0E MFI Pump - Rebuilt
    By jbell959 in forum For Sale: 911 Parts
    Last Post: 03-10-2010, 07:37 PM
  3. 2.0S Bosch MFI Pump (Rebuilt)
    Last Post: 03-05-2010, 07:23 AM
  4. Rebuilt MFI fuel pump
    By Frank Beck in forum For Sale: 911 Parts
    Last Post: 07-09-2008, 11:07 AM
  5. Replies: 7
    Last Post: 05-17-2007, 01:40 AM
