Results 1 to 2 of 2
Thread: Hand Brake Blinking Light?
    Question Hand Brake Blinking Light?
    I replaced my front rotors yesteday.
    My parking brake light that blinks when handbrakes are applied and stops blinking when you put down the hand brake.
    Well, now it will not stop blinking any idea why???
    Any idea why did this happen?
    thank you for all your responses
    The blinking light is a result of the switch on the M/C being tripped. Reset it by pushing in on the rubber cone on the side of the M/C. I will click and stay in and not pop out. That will put the light out. Or, do like I do and pull the wires off the switch entirely. The old switches had 2 terminals; the new have one and you have to make up a ground slice to get it to work. You have to figure out which one is hot. Lot of trouble.
  1. Blinking brake warning light
    By rpc356 in forum Technical Info
    Last Post: 06-16-2012, 04:02 AM
  2. Hand Brake Switch - light
    By drwhosc in forum Technical Info
    Last Post: 07-27-2009, 05:47 AM
  3. Replies: 2
    Last Post: 07-18-2008, 06:11 AM
  4. Hand Brake Light Issue
    By joe912 in forum Technical Info
    Last Post: 10-30-2006, 11:07 PM
  5. Hand brake Blinking Light?
    By jtkkz in forum General Info
    Last Post: 11-12-2004, 12:13 PM
