Thread: Calling headliner, aand SWB experts;
    Just acquired another 67S, and have some inquiries;
    Headliner, is a grey taupe color, and feels sort of felt like; Is this original or has it been replaced. My other 67, has the typical off white perforated type;
    Secondly; Ownership shows this as a 68S, but Chassis no. corresponds to 67S type of numbering; Also,door handles are the 68 style; So is this a 67, or a 68?
    Thanks;
    Seattle WA
    Peter,
    Never seen a felt type headliner in all the early cars I have seen.....probably a replacement.
    Door handles....well, if you were at the end of the 67S run, you MIGHT have gotten a changeover handle.
    I owned the second 69S targa built.....the car was ALL 69, not a single 68 item on it. It was completely original, paint, interior, etc.
    Regards,
    Eric
    There are many differences between the 67 and 68 models
    Instrument: 67 has green lettering, 68 is white
    Heater lever: 67 is in front of handbrake, 68 alongside
    Steering column: 67 has support running to trunk floor, 68 doesn't
    Door trims: 67 has a single pocket running from front to rear, with a hard "bow" on the back third and smooth trim, 68 has short pocket below armrest and basketweave trim
    Door handles: you know about
    VINs are quite different: 67 is 6 digits, 68 is 8 digits beginning 118......
    Your headliner sounds wrong, my 68S has perforated beige
    Card carryin' member! mjmoran's Avatar
    Aug 2003
    Many times during registration the car will show to be a later car than it was. I had a 60 coupe that had been reg. as a 62...it was bought as new in 62 for some reason...If the VIN shows 1180.... its a 68 if it is 30....S than its 67. If its a late 308...S car could have the new type handles as this was a safety item and I bet Porsche wanted to implement it asap. taupe headliner...nope never seen it!
    Michael
    72 911S Coupe, Sepia Brown
  1. Calling on Tire Experts
    By 72targa in forum Technical Info
    Last Post: 10-13-2011, 02:29 PM
  2. Calling All Experts! Does this Look Original?
    By wolfgang1 in forum General Info
    Last Post: 09-30-2011, 11:31 AM
  3. Calling all fog lights experts
    By jzajfen in forum General Info
    Last Post: 10-30-2009, 08:58 PM
  4. Calling all engine # experts...
    By larwik in forum Technical Info
    Last Post: 04-18-2005, 03:27 AM
  5. Calling headliner, aand SWB experts;
    By Peter Aziz in forum Technical Info
    Last Post: 11-15-2004, 05:52 PM
