Results 1 to 8 of 8
Thread: suspension & brake questions
    Hey, I am about to really expose my ignorance here. I am interested in upgrading the suspension and brakes for spirited street driving and perhaps ocassional track time. I have a 70T with black front struts. What inserts can I use and what recomendations, same goes for the rear. Torsion bar diameters? I have seen on various sites that 21mm front and 26mm rear are a good balance. Also, I saw an older post that said that there are Wilwood calipers that will work and if so where are they available? No doubt you can tell...a new and excited owner. Thanks, Cort.
    Apr 2003
    Portland, OR
    Quote Originally Posted by goofycarp
    Do a search here and at Rennlist (http://forums.rennlist.com) and pelican (http://forums.pelican.com) for much of your information. Steve Weiner posts here and the other boards and knows a bit on the topic as well.
    Harry
    Member #789
    2009 MB C300
    A buddy of mine who is a member here (GreenT) did a major suspension upgrade on his 70. I don't know the details, but I do know he was very happy with the result....and I think it was all late model OEM stuff he got out of a salvage yard.
    Leaf green 72T, SOLD!
    Gone back to my MoPar roots!
    Apr 2003
    Portland, OR
    Cort,
    I should add that the best investment you can make is not hardware for the car, but seat time for the "nut" behind the wheel. Even in stock form, these cars, in skilled hands, can exceed the performance of many other cars that have had "performance upgrades". Them Porschie engineers did not leave much on the table.
    Harry
    Member #789
    2009 MB C300
    Goldmember ttweed's Avatar
    La Jolla, CA
    Quote Originally Posted by HarryD
    I concur. However, if you are determined to update before you learn to drive it at the limit, the most cost-effective option might be (as LeafGreen suggests) buying the entire front end from a 3.2 Carrera and bolting it on.
    The 21/26 torsion bar choice is a good compromise for a street-driven car. Don't forget that wheel and tire choices could make the biggest difference in your car's performance, however.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Here are my choices after a good study on the subject. Hopefully, I will have found a nice balance of components. 21/26; 19mm sways, both ends; 4 Koni Sports; all on narrow body riding on 15 x 7s all around.
    Oh, and new Elephant polybronze bushings and adjustable drop links.
    Thanks for all the good points. Regarding tires, here's what the car has on now, Michelin "Energy MXV4" 195/60/15 and not sure on the width of the rims, is there a stamp on the inside of the rim? Tire recommendations? Thanks. Cort.
    Yes, there are a couple of stamps on the inside of the rim if you have Fuchs. One might say 15 x 6J, and there is a part no. that will start with 901 or 911.
  1. Questions for the suspension experts
    By Chris Pomares in forum Technical Info
    Last Post: 07-15-2013, 01:16 PM
  2. Swb suspension questions
    By andrea70 in forum General Info
    Last Post: 04-03-2013, 07:31 AM
  3. Suspension rebuilt questions ...
    By RS-GT in forum Technical Info
    Last Post: 05-24-2008, 12:46 PM
  4. Suspension questions
    By CamBiscuit in forum Technical Info
    Last Post: 05-14-2008, 04:28 AM
  5. Suspension questions
    Last Post: 11-28-2007, 12:47 PM
