NOw that I have a good idea of what damage financially I am going to suffer by restoring my 911S....I now need to know WHO to take it to...or the best in the various sub catagories...Engine/trans, Paint/bodywork, Suspension/brakes and Interior...
Master of the Buffet
Voice of Reasoned Conservatism
I highly recommend MotorMeister for the engine work. They can do amazing things with used parts and they're inexpensive...hell, they're a bargain. Ask for Roy. Happy to help.
RGruppe #183
Jens, THAT'S JUST MEAN!!!!!!Originally Posted by Jens
Bahia Red '72 911S
Meerblau PTS 2019 Speedster
ES #333
I thought a 2 stage with a clearcoat was the way to go.
can someone explain why a single coat is the way to go?
Single stage is what the factory used, except for metallic colors which used a clear coat. It's more authentic.
RGruppe #183
But, but Stacy! They said they would rebuild my motor for $2500 with a GUARANTEE. Ya cain't go wrong widdat!! And they guarantee it. No worries...right?!Originally Posted by 69Sman
RGruppe #183
sorry to highjack this thread;
what were the metallic paint?
is silver one?
uhm...yes...by definition...
RGruppe #183
OK...Ok...if a 'rebuid' is the same as a 'rebuild' GO FOR IT!!!!!!!!!!!
I think that $2500 for a 'rebuid' is GOOD deal. Is that just a top end or ?!?!?!?!?! ..
Bahia Red '72 911S
ES #333
TABs,
Don't know where you are located.
THE best Porsche engine shop I know of is in Oregon.
ROTHSPORT Road and Race.They did both my motors.
Not cheap, but EVERYTHING will be done correctly to factory or better levels.
I too would recommend installation of the case piston squirters on an early case along with the oil by-pass modification and a later oil pump.The 2.7/3.0RS, early 2.7CIS, and SC cylinders were Nikasil. The early style E/S MAHLE from 2.0-2.4 were BIRAL.
The Nikasil cylinder/piston combination required the oil squirters. The other set ups simply get better lubrication and cooling.
Case saver inserts are a good idea too, even with steel head studs.
Any engine that goes through RS will receive all of these goodies and more.
Again, not a bargain shop. But if you want the best...
Tom Wilkinson
R Gruppe # 130
