Thread: H4 city lights...how to wire in?
    Card carryin' member! mjmoran's Avatar
    Aug 2003
    Does anyone have a diagrame on how to set up the city lights on H4s to work correctly on a US car?
    Michael
    72 911S Coupe, Sepia Brown
    Nov 2002
    Worshington State
    CAUTION PURISTS do not read any further: I don't have a diagram, but I wired mine to each front parking/accessory light. It was very easy, I just dropped the wire down the headlight bucket drain hole and T'd it into the wire (don't ask me what color). The only draw back is that if you do use your parking lights (correctly - using the turn signal stalk) the city light also be on.
    Aug 2003
    Yes, I had thought of doing that and adding a relay to shut it off when the headlights are on. I believe for correctness it is first pull of the switch side (town) lights and running lights, second pull side lights off and head lights on.
    Michael
  1. Replies: 1
    Last Post: 06-17-2013, 10:37 AM
  2. Inspection near Atlantic City
    By Porschist in forum General Info
    Last Post: 04-18-2011, 11:26 AM
  3. How wire Cibie headlights with parking lights?
    By jameshtaylor in forum Technical Info
    Last Post: 07-13-2009, 05:23 AM
  4. City Lights?
    By Dmill in forum Technical Info
    Last Post: 01-28-2007, 08:55 PM
  5. H1's and "city lights"
    By mike walker in forum General Info
    Last Post: 07-03-2006, 10:51 PM
