Results 1 to 10 of 17
Thread: Shift Coupler
    Shift Coupler
    I need to replace the bushings on my shift coupler. There are several options. I could replace the factory bushings, upgrade with aftermarket bushings, replace with factory coupler or upgrade with aftermarket.
    For a small part there seems to be a lot of choices and I am wondering if the additional cost is worth it.
    Apr 2003
    Portland, OR
    Earl,
    For me, I went with factory replacement bushings and it was a significant improvement. Didn't really investigate too much, I just had Mike put them in and adjust as needed.
    Harry
    Member #789
    2009 MB C300
    Hello Earl,
    I am very sorry to hear about this.
    Unfortunately this minor component failure is only the tip of the iceburg.
    When the coupler goes bad typically it means the transmission has failed too.
    Vibrations from the misaligned coupler causes massive internal damage to the gearbox rendering the entire unit worthless. If this is not caught immediately, the engine will be destroyed as well.
    I suppose you can try a new coupler, but be prepared for a full mechanical overhaul and/or replacement of all drive train components.
    TVW
    p.s. Call me when it comes in and we'll get it shifting better than ever.
    What!?!
    I get it now, the shift coupler is also directly works in harmaney with the muffler bearings, when these fail it stops rainy, then your wife will not love you any more. Hurry up and get on it, there is more at stake then just finding gears when you shift, which is all I have ever noticed, BTW I vote for factory bushings ,Fritz
    Apr 2003
    Portland, OR
    Quote Originally Posted by Fritz A. Ficke
    Fritz,
    Not true. Everyone knows that a failed Kuhneutson Valve is the real culprit.
    Fortunately this link will take to an outfit that can provide a high quality Forged Kuhneutson Valve.
    Harry
    Member #789
    2009 MB C300
    Thanks Harry, I stand corrected, I forgot all about that valve, I hope this help Zeke he did sound a little confused about Thomas posting, Fritz
    Thanks for the warning Tom... and the help!
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    I've used the round holed bushings vs. the elongated ones and found that it's just that much tighter a feel. Minor surgery and $20 or so. Make sure the front bushings are tight too.
    People swear by the Stomski coupler with zeeero play. At $180 I guess that you'd never have to worry about them again.
    RGruppe #183
  1. FS: shift coupler cover
    Last Post: 02-07-2014, 09:19 PM
  2. WTB: Shift Coupler for a 1970 911
    By sam71TargaS in forum For Sale: 911 Parts
    Last Post: 09-18-2013, 06:25 AM
  3. 901 Shift Coupler FS
    By Scooter 911 in forum For Sale: 911 Parts
    Last Post: 06-21-2011, 05:40 PM
  4. '72 - '86 Inner shift rod/coupler boot. NOS
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 03-23-2008, 09:13 PM
  5. 901 shift coupler adjustment?
    By Flieger in forum Technical Info
    Last Post: 12-23-2007, 04:41 PM
