I would like to find out more about the paint code on this car. Does anyone know? It's one of our member's cars.
Thanks.
Thanks.
RGruppe #183
Any chance its Irish Green and that pic is a little off? Thats the brightest grass Ive ever seen.
Yeah, the color tones in general are a bit unusual. I sure would like to know the paint code or number. Looks to be metallic, so Irish Green is suspect.
RGruppe #183
Great car. It actually looks metallic in that pic
It sure is a unique color. The side shot background coloration looks a lot more natural so it might be a fair representation of what it looks like in the flesh. ???
RGruppe #183
Trying to bring the grass back so it looks somewhat real.
Color no idea.
Jens,
I believe the color is called simply "green metallic" and is code 230. Here is a shot of the color plate and surrounding paint area. Despite the smudge around the plate, I am almost sure that the doorjamb area is the original paint. Not the same car as the one you posted, but it sure looks like the same color to me. I have other shots of this color. Let me know if you would like any others.
There are several metallic green colors. The paint codes and color chart numbers get confusing. I think it's easy to presume that the same color was carried over into different years with different codes and paint chart numbers. I don't think that's necessarily the case.
Here's another; Special Order Dark Green Metallic-
RGruppe #183
Does anyone have a pic of the 1970 paint chart #221 Metallic Green (paint code 8383) on the car?
'68 had a Special Order #6852 Metallic Dark Green.
There's also #224 Metallic Green listed as a '72 Special Order color.
Special Order #230 Metallic Green is a '73 color. WTF?!
So much for the much touted Teutonic regimentation! Vere ist der logic?!
RGruppe #183
... not much help bud
