Results 1 to 2 of 2
Thread: Bosch Distributor???
    Question Bosch Distributor???
    Will a 1969 911S bosch distributor bolt right into a 1971 911T.
    I have a marelli distributor and a friend of mine has a '69 911S bosch dist. that he is willing to sell me if it fits.
    Will the S curved dist. be ok to run with my stock T motor?
    My T is euipped with a MSD ignition, PMO carbs.
    Thank You for your replies
    The S distributor should work fine. I had a 67 S distributor in my stock T for years before upgrading it. Try the initial and total S timing specs too. Should provide a little more low end torque, but listen very carefully for any borderline ping.
    Also, consider adding an optical trigger to replace the points (Crane or MSD).
    Sherwood
  1. FS: NOS BOSCH distributor 0 231 159 002 JFDR6 in bosch box
    Last Post: 03-08-2013, 10:55 PM
  2. Replies: 2
    Last Post: 10-04-2012, 09:31 PM
  3. Help on value of 65-67 Bosch distributor
    By EA911 in forum General Info
    Last Post: 11-29-2011, 02:16 PM
  4. FS Bosch 2.0L Distributor
    By byron in forum For Sale: 911 Parts
    Last Post: 04-29-2011, 07:52 PM
  5. Bosch 2.0L Distributor
    By jbell959 in forum For Sale: 911 Parts
    Last Post: 03-10-2010, 02:48 PM
