Results 1 to 2 of 2
Thread: Distirbing clutch (?) noise, any ideas
    Question Distirbing clutch (?) noise, any ideas
    Hi, My 70 911t with an alleged rebuilt 901 is doing some weird stuff. While accellerating in a "normal" fashion, I push in the clutch and shifts without any noise whatsoever; however when pushing in the clutch to shift under full throtle I get a horrific clatter that continues even when I let the clutch out in neutral. I did replace the driver's floor board recently and had to readjust the clutch stop. Is the clutch pedal going too far and do I need to readjust or is something more sinister going on. Thanks for any insight. Cort Chambers.
    Cort,
    Can't say I have any experience with a 70, but a few ideas come to mind. I suppose It's possible for the clutch release arm to go too far and catch the spinning flywheel assy. (I had this happen on other cars). I would say increase the pedal free play a bit and see if it changes. As far as why it only does it under WFO, I would suspect old and spongy motor mounts are yielding to the engine torque and causing stuff to move that shouldn't move.
    Alex
    Leaf green 72T, SOLD!
    Gone back to my MoPar roots!
  1. Mystery Noise
    By guycrosby in forum Technical Info
    Last Post: 04-24-2011, 10:53 AM
  2. door noise
    By scargo70 in forum Technical Info
    Last Post: 03-21-2011, 09:28 AM
  3. What is that noise?
    By raspy2point2 in forum Technical Info
    Last Post: 03-30-2010, 08:59 PM
  4. Engine Noise!!!!!!!
    Last Post: 07-23-2005, 03:44 PM
  5. transmission noise?
    By james in forum Technical Info
    Last Post: 01-05-2004, 11:57 AM
