Anyone have an opinion on the best shops for MFI rebuilds and throttle body refurbishments? What kind of $ am I looking at?
Thanks for any help.
A.T.
A.T.
A.T., I had the MFI injection pump rebuilt with an RS space cam by Hanz at H&R Fuel Injection (in NY) for $950, and I sent a rough set of 2.4T stacks, throttle bodies and ALL the linkage to Eurometrix (in MA). They were completely refurbished (like new!) and bored to S/RS specs. That set me back a little over $1,900.
Jim Richards
Aubergine 1973 911E Sunroof Coupe w/ 2.7RS MFI
Early 911S Registry Member #589
GruppeB #911
Jim,
Thanks for the info. What was your turnaround time? I've been told to make an appt. several weeks out.(before removing and shipping) Once at the shop 4-6 weeks?
[SIGPIC][/SIGPIC]
Ray Crawford
Early S Registry #271
R Gruppe #255
'70 911 S Coupe 2.9 w/MFI Twin Plug "Flairs n Chairs"
'72 911 S Targa 2.4 w/MFI
Ray, that sounds about right for Eurometrix. Hanz at H&R is faster for his part of the injection system. Hanz will likely tell you to send your injectors for testing. I did, he tested them and told me how many were bad or marginal, and then he had me send him a new set of injectors that I purchased to verify they were good. All of the injector testing was done without charge. Hanz is very easy to work with.
Here's what the stacks and throttle bodies looked like when I got them back:
Jim Richards
GruppeB #911
I can vouch for Hans who is beyong knowledgeable. His shop is close by. His shop uses the old Bosch benches and testing equiptment which is really interesting to see. Hans goes back to the Peter Gregg/IMSA days. Matt is also aces. By having both components of the injection done you are really doing it right. Very little adjustment was needed on my engine. Good luck.
Best,
Don
Another rec.for Matt at Eurometrix.
He did a fantastic job on my Webers / 6 weeks.
Du must schwein haben
901/05 #305701
Bultaco Metralla 62 M8
1968 BMW R69S
Early911SReg #606
Do you guys have an addres and number for H&R Fuel injection?
Max L
It was always recommeded to me to go to the following for repairs to our mechanical fuel injection pumps:
Pacific Fuel Injection Service
153 Utah Avenue
South San Francisco, CA 94080
Tel: (650) 588-8880
I would assume they'd have a recommendation on throttle body rebuilders?
Any of these guys would be able to help you out
Hans at H&R, NY - pump - 631-589-1600
Gus at Pacific Fuel Injection, CA - pump - 650-588-8880
Henty at Supertec, CA - everything - 714-429-1863
Matt at Eurometrics, MA - stacks & throttle bodies - 978-448-2557
Harry Beiker, OR - stacks & throttle bodies -
Steve at Rennsport, OR -
EBS Racing, NV - stacks & throttle bodies - 800-462-3774
