Results 1 to 2 of 2
Thread: 1968 911L Brakes-Conversion?
    Question 1968 911L Brakes-Conversion?
    Hello Everyone,
    I have a 1968 911L with calipers that are sticking in the rear as if the piston won't release. I want to possibly rebuild them, but was also wondering if it is possible to retro-fit the standard 911 brakes onto a 68 911L because the car as you know has the "S" brakes but finding parts for them is very difficult. I.e. the rotors and caliper parts are nearly impossible to find unless you go thru the dealer. Any ideas on locating parts for this car and/or if it is possible to put on standard 911 brakes without alot of mods would be most appreciated.
    Joe L.
    Goldmember ttweed's Avatar
    La Jolla, CA
    Search the forums--you can replace the rear rotors with early 944 parts with some slight machining. There was a thread about this awhile back. The calipers should be rebuildable. The problem is the E-brake hat on the later 911 brake rotors won't work with the SWB cars. Apparently, the 944 rotor is almost perfect, just needs to have the outer edge turned down a little. Haven't tried it yet myself, but I will when I need new rotors on the rear of my '67S.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
  1. 1968 s brakes
    By Richsmith901 in forum Technical Info
    Last Post: 12-08-2012, 01:00 PM
  2. 1968 911l
    By autobahnx in forum Technical Info
    Last Post: 12-04-2012, 10:27 AM
  3. 1968 911L Hot Rod
    By ennisk1 in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 09-13-2012, 04:31 PM
  4. 1968 911l
    By juche_namja in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 07-07-2011, 06:46 AM
  5. '68 911L/S Brakes
    By B D in forum Technical Info
    Last Post: 09-18-2006, 07:31 AM
