Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: How wide can you go for SWB cars? (tires)
    I'm in the process of moving from a 2.0S motor in my SWB '67 to a built out 2.7 motor. The new motor makes a LOT more power and torque so I want to improve my cars ability to put power to the ground by moving to larger tires. The PO put 195/60's on there right on a reproduction fuchs wheel. I want to go as wide as possible, so my question is this:
    How wide can you go on a SWB car?
    My mechanic says if I run a few more degrees of rear camber I can fit 215's on the back. Does anyone have suggestions? I'm planning on running a 185/70 on a 15x6 fuchs on the front with 215/60 on 16x7 on the rear. Does anyone have experience running this setup?
    -=Nick
    Seattle WA
    Not running 16's, but I am running 7 x 15 911R wheels on the rear....fender lips are rolled, and I've got 225/50's on wheels, spring plate bolts needed to be shaved down.
    regards,
    Eric
    Apr 2004
    Quote Originally Posted by jeremica
    I'm planning on running a 185/70 on a 15x6 fuchs on the front with 215/60 on 16x7 on the rear. Nick
    Nick;
    That will be quite a diff front to back. Why not fit a little wider fronts as well ?
    What's the theory there ?
    Du must schwein haben
    901/05 #305701
    Bultaco Metralla 62 M8
    1968 BMW R69S
    Early911SReg #606
    Question Difference in front to back
    I was entertaining the idea of running the 185's on the front and the 215's on the rear since those were the factory sizes for Carrera 2.7's, 3.0's and 930s from '73-'77. I imagine that a wider front tire would delete some of the understeer.
    How wide can you on the fronts without having to dial in more camber?
    Apr 2004
    Those later cars all have the longer wheel base.
    I was thinking, with that much power on the shorter wheel base , wouldn't it be better to have more rubber up front to help balance and control the livlier back end ?
    I don't know that that is the way to go, I am asking.
    901/05 #305701
    1968 BMW R69S
    Early911SReg #606
    I want some "skinnies" on the back so I can re-live my Corvette "Burn Out" days. 165's! and an LSD. Man could you lay down some stripes!!!
    Tom
    Early S Registry #235
    rgruppe #111
    Seattle WA
    Put it on the Corvette list...."shorty"......
    E
    Quote Originally Posted by Soterik
    E
    Nobody understands me...
    Tom
    rgruppe #111
    Apr 2004
    I didn't mean more rubber in the front than in the back - just more than 185 with 215's or 225's.
    But then I don't even understand me.
    901/05 #305701
    1968 BMW R69S
    Early911SReg #606
    Goldmember ttweed's Avatar
    La Jolla, CA
    That's kind of an odd combination--I don't think you're going to find many people who have run those sizes on a SWB car. I don't quite understand the 16s on the rear w/ 15s on the front. What are you trying to accomplish with that? If your goal is to fit as much rubber as possible in the rear, I don't think you could do much better than Eric's setup, w/ a 225/50-15, and you need a custom offset 7" rim to do it. I would pair that up with 205/60-15s on 6s in the front and you would have a well-balanced setup.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
  1. WTB: '67 Wide L Caliper
    By julian67 in forum For Sale: 911 Parts
    Last Post: 12-30-2013, 08:09 AM
  2. WTB: Wide Steelies
    By tpweiss9953 in forum For Sale: 911 Parts
    Last Post: 06-17-2013, 10:38 AM
  3. WTB: Wide L-Calipers
    By Neunelfer in forum For Sale: 911 Parts
    Last Post: 07-22-2010, 06:17 AM
  4. Forza 2 - Gulf colors and cars, cars, cars...
    By kenikh in forum Off Topic
    Last Post: 03-05-2007, 12:34 PM
  5. Wide L Calipers
    By swb911s in forum For Sale: 911 Parts
    Last Post: 02-17-2006, 10:55 AM
