Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: how to "unpolish" fuchs for that raw look?
    first off - thanks nick for the pic.
    how would i achieve this "raw" look with my current polished wheels? sandblast: what medium?
    handsanding: what grit?
    chemical: what chemical could be applied?
    thanks in advance.
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    Goldmember ttweed's Avatar
    La Jolla, CA
    Quote Originally Posted by bob tilton
    Bob- I would media blast them for an even texture. Call Diane at Al Reed's, she does this for the "RSR" frosted look, but I don't know what media she uses.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Media blasting them...
    Bob-
    Just to add a little to ttweed's post I will add the following:
    For the raw look (i.e. no surface sheen at all and a slight roughness) you could have them blasted with a media made by dupont known as Starblast. Its finer than sand but not by a lot. The only problem is that the wheels will be slightly etched and will attract a lot of dust, so you'll spend a lot of time cleaning them.
    For the low-sheen raw aluminum look you could have them blasted with glass bead. This will give a very slight sheen in the right light. The color will be a tick lighter than starblast will give. The glass bead will peen the surface slightly and will attract less dust than a star-blasted finish but will fingerprint easily...
    We do both types of blasting at my shop for the vintage BMW crowd-a lot of guys with vintage minilites or other aluminum wheels like the glass bead look. Either way you do it, it will look good. Clearcoating the wheels afterward will help seal the surface, but the longterm adhesion of clearcoat to bare metal is not that great to be honest, and it will slightly darken the raw finish versus its "straight from the blaster" look.
    Hope this helps.
    70 911T
    72 2002tii
    72 Alfa GTV
    68 BMW 1600 Alpina clone
    Dec 2002
    Birmingham, MI
    Lordy - that is just about the perfect wheel to body relationship - AND period sidewall section... JUICY!
    My understanding is the regular anodized finish is anodizing over a polished surface. The "raw" finish is anodizing over a sandblased surface. This was done because the factory polishing equipment wouldn't fit down into the deep RSR wheels.
    Hard to tell, but the wheels in the photo look sandblasted and clearcoated (with no anodizing). Sort of a raw - RAW look!
    Jared
    '73 911S #0793
    '69 912_ #0602
    Early S #0454
    RGruppe #0391
    I glass bead blasted mine and then painted them with a clear - it gives a nice low sheen, but would be difficult to polish out later if I wanted to. I'll look to see if I have a pic.
    Regards,
    Andrew M
    Check with Al Reed. He is my wheel man. No complaints! Has a lengthy wait time now. Don't rush him, you will not be disappointed.
    Mike
    Vollgas!
    You can also clear anodize them versus clear coating, using a process just like Al Reed would use. You can even do it at home:
    http://www.caswellplating.com/kits/aluminum.htm
    There are also a lot of enthusiast forums online that are all about home anodizing. It is pretty cheap if you DIY.
    This should solve the fingerprints problem and be more durable than clear lacquer. It is quite a bit more expensive, but most likely cheaper than paying someone to do it. Plus you'd have the tools to do it again.
    thanks for all the great info guys. i'm thinking i should find a set of deeps 6s and have this treatment done as everyone describes above. jay sycip called after reading the post and said it would be a very simple process to media blast and "soft" clear powdercoat the wheels. in the end i want the raw look with black.
    now i gotta figure out how i can write a ck for a set of deep 6s after that engine transplant.
    _B
    www.werkcrew.com
    Bob
    A fellow rgruppe member (Ian) from Pleasanton was selling a few deep sixes.
    He has 9 of them.
    http://forums.pelicanparts.com/showt...hreadid=211100
    check with him if he can give you a deal on a set.
    or
    just have my brother blast it and have him do the same he did with my wheels.
    Raw look Fuchs
    So, does anyone know the wheel and tire sizes in that photo? I was shooting for that on my car with deep 6s and 195/65s front, 215/60s rear but didn't quite hit it. Think I'll do up a spare set of flat 6s in the raw and try to get closer with to this look.
    Terry
  1. WTT: Very nice 15"s for Polished Spoke 16" 7" & 8" Fuchs.
    By Craig T in forum Free, Trades, and Swaps
    Last Post: 10-12-2013, 10:03 AM
  2. WTB: (1) Fuchs "Deep Six" w/heart 15"x6" Price: YTM
    By Johnlips in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 04-28-2013, 01:14 PM
  3. Replies: 12
    Last Post: 05-21-2012, 01:06 PM
  4. WTB: 15 X 6" "good driver" Fuchs in date range 11/72 - 3/73
    By Eminence Gris in forum For Sale: 911 Parts
    Last Post: 07-03-2011, 10:36 AM
  5. Original Fuchs Wheel Set, 6"x16" & 7"x16" (Refurbished)
    By Jorge Perez in forum For Sale: 911 Parts
    Last Post: 07-13-2010, 12:35 PM
