Thread: Rear Wheel Widening SWB
    I was talking to Al Reed today about widening wheels and refinishing them. I have discussed several refinishing options with him. I have several regular 15x6 wheels kicking around that may serve as donor wheels to widen.
    Has anyone widened any wheels for the rear (NON FLARED/ NON ROLLED FENDER LIP!!!!) for a SWB car. I have my 4.5 x15s but I use deep 6 wheels on all 4 corners for regular driving. I like the positive offset of the deep 6 in the front and rear. I am using a 1/4 spacer and they fit beautiful w/o any rubbing.
    Now I would like to get a bit wider rim in the rear. Therefore I can only gain by adding negative offset (inward). I wonder if I can widen a wheel to 6.5 or 7" w/o any issues. I prefer not to use a deep 6 to widen. I do have extras that I can do this with, but I prefer to use a cheaper 15x6 wheel.
    Any comments from anyone that has gone this path??
    Mike
    1967S SWB
    Vollgas!
    Apr 2004
    Mike;
    You can get some R Fuchs - 7's ,They were made to fit the SWB (BIG $)
    You could call Harvey Weidman - he can also make 7's for you
    You could roll the fenders and put on later 7's - or 8's
    There are alot of threads on this, do a search here and on Pelican
    Good luck;
    Du must schwein haben
    901/05 #305701
    Bultaco Metralla 62 M8
    1968 BMW R69S
    Early911SReg #606
    I prefer not to modify the body (i.e. roll fender lip) at all. It must remain stock or easy to convert back to original.
    What offset does the R wheel have. Is the front of it like a deep 6 or like a regular 15x6/7, or 8. I want to make a close replica of the R wheel. Does the R offset fot the rear w/o modifying the fender lips?
    Thanks all,
    Mike
    Vollgas!
    Apr 2004
    Mike;
    49mm offset
    same face as deep 6's
    that's what it as made for - to fit the SWB fenders
    Go to the S Reg tech page - there is a great chart and specs and diagrams.
    901/05 #305701
    1968 BMW R69S
    Early911SReg #606
  1. Widening fuchs for RSR
    By Scotty B in forum General Info
    Last Post: 06-03-2013, 08:00 PM
  2. Widening steel wheels ?
    By RS-GT in forum Technical Info
    Last Post: 06-26-2009, 06:20 PM
  3. Steel wheel widening shop recommendation
    By EA911 in forum General Info
    Last Post: 03-23-2009, 04:29 PM
  4. Widening deep 6 to 7R specs
    By yeti in forum Technical Info
    Last Post: 06-20-2007, 01:16 PM
  5. Weidmans wheel resto and widening - update
    By Cornpanzer in forum General Info
    Last Post: 03-23-2006, 05:28 PM
